Hey everyone. I had a question thats been buging me for awhile. I just picked up a 91 coupe and i'm having clutch problems. He said the clutch needed to be adjusted but neways i have to push the clutch all the way to the floor to get it to shift. It wont go into any off the gears sometime. It's a tremec 500 that has a few thousand miles on it and a spec stage 2 clutch. Why is it that i have to push the clutch to the floor and why does it grind into reverse sometimes? Does the clutch need to be adjusted? If so what do i need to do/or buy to get this problem to go away? Is the reason i'm grinding gears because it needs adjusted? Thanks and any help is great!!
Anyways, it worked so I'm happy
