clutch help needed!?!?
  • Thread starter Thread starter 5_Oh_Bird
  • Start date Start date May 4, 2004
5_Oh_Bird
  • May 4, 2004
i have a 1970 302 motor that i rebuilt and i want to mate it to a t-5 trans. it is going in a fox body. i was just wondering, will a flywheel for a 1970 motor be compatable with a 79-93 clutch kit. i was thinking about using an aluminum flywheel but i read they are not recomended for street use!? is this true and why? last question is with my motor, it has the following :9.6 to 1 speedpro pistons comp cams 270h cam, mac 1 5/8 shorty headers, comp hydraulic lifters, melling high volume oil pump, holley street dominator intake, holley 600, mac h pipe and cat back exhaust, accel 300+ racing ignition. is this a good street combo and what kind of power should i expect out of this? thanks for any advice that can be given. i havent got the engine started yet due to elctrical problems
bgjohnson
963
johnston,iowa
May 4, 2004
  • May 4, 2004
I think I can answer some of your questions. the reason they don't recommend an aluminum flywheel is because it doen't smooth out engine vibration well enough and isn't to comfortable to drive ecspecially with a 5spd. now I don't know about the 79-93 clutch kits mating up to it, i can't really think why they wouldn't and as for power, i'd say 300+ at the crank, but i'm not as good guessing carbed motors opposed to EFI HP #'s.
V
v8only
2,378
22
49
May 4, 2004
  • May 4, 2004
The 302 engines up until I think 82 used a 28 oz flywheel/flexplate, 83 or so they changed to a 50 oz style.
the flywheel you refer too will not work, and does not have the correct weight.
I'm not sure as to the teeth on the 86-93 10.5 inch flywheels, but I'm pretty sure they are 164 teeth
What you'll need is a flywheel with a 28 oz displacement to work with that 70 302, and I'm fairly certain 164 teeth to work with the t5 bell and starter. Ford never made such a beast, but the aftermarket did, check ebay and summit.
well, ****, I just re read your post. your older flywheel is I think 157 tooth. I'm pretty sure the t5 has a bigger bell designed for the 164 tooth bigger flywheels, so if you use the old school flywheel, then it may not work with the starter.
what does the older flywheel measure??? todays clutches are designed for a 10.5 inch flywheel.
Anyhow, I may have raised more questions than answers, but you have the correct ammo to search further now, GOod luck!
85GTlover
704
  • May 4, 2004
You got to be in the 200+hp or more as for the fly wheel I think it says not for street just because its made for higher rpm's what does that have to do with it nothing. They are not cheap I would say if you were a racer, yes but steel ones aftermarket would be
better save money for other things. True about clutch too. 86+ is bigger, better, you want to get a fly wheel that lets you run 86+
clutch. Get a aluminum driveshaft instead of """"" flywheel...you will appreciate that more. Unless you really mod your motor.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
H
New Built 91 Foxbody electrical failure. Need help
  • hassler
  • Aug 18, 2025
Fox 5.0 Mustang Tech Aug 21, 2025
limp
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
A
Need some info on putting a 2002 4.6l in a 1997 gt.
  • Austin4.6l
  • May 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2025
Austin4.6l
A
