Clutch help!
  • Thread starter Thread starter 5.0Torx
  • Start date Start date Jun 9, 2009
5.0Torx
252
Jun 9, 2009
  • Jun 9, 2009
hey all
I took pics of whats going on with my clutch.
Got under it today and found that i do not have a clutch fork seal. I conveniently drove through a massive puddle in a rainstorm a while ago, and ever since then my clutch has been groaning and not engaging/disengaging smoothly.
The first two are clutched out. The second two are clutched in. The clutch was replaced with a king cobra 5 years / 40k miles ago. Havent adjusted it because it has been just fine. It was only a week ago after driving through the puddle that it has started to act up.
Whats the diagnosis?
TIA
R
rwood126
161
mCdONOUGH, GA.
Jun 9, 2009
  • Jun 9, 2009
Cable looks pretty rusty....clutch spring may be the same.
You might want to lube the cable a bit...and maybe have the pressure plate check out.
Boot is still available from ford E6ZZ-7513-A $49.98
1990MustangLX50
89
  • Jun 9, 2009
How deep of a puddle was it? deep enough to get into the bellhousing
5.0Torx
252
Jun 9, 2009
  • Jun 9, 2009
how do you lube the cable?
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
