- Oct 22, 2005
- 75
- 0
- 0
ok i went to my shop today i started the car keep in mind its still on jack stands i rolled under it while it was running i grabbed the fork it vibrates really bad any ideas?
lmarinukjr said:ok i went to my shop today i started the car keep in mind its still on jack stands i rolled under it while it was running i grabbed the fork it vibrates really bad any ideas?
I agree.1991vert said:loose clutch cable or the fork fell off the bell housing "joint"
Same here.v8only said:interesting, I've used that TOB that came in the ford clutch kit three different times and never had one problem.
lmarinukjr said:ok i took it apart check everything and the winner is fastimes69 the preasure plate wa****ting the bellhousing i used a grinder to shave some more off ill re install it on sunday ill keep u updated
Glad I could be of help!! I still don't know why these pressure plates do that? I know the Motorsport clutch sets don't give problems like that...Laterlmarinukjr said:everything is fixed the only problem im having now is the trans seal at the driveshaft is leaking
