Clutch issues
  • Thread starter Thread starter 65wetherby
  • Start date Start date Aug 14, 2005
65wetherby
  • Aug 14, 2005
65 Mustang with 289, 4 spd manual T-10 trans. Replaced clutch last year when I first got the car. Also put a clutch return spring in to assist in the return of the fork. This morning when I drove the car it had a hard time going into first and staying in all gears but 4th. 1. I think I may have got the wrong clutch from O'Reilly's. 2. How do I make sure that I'm putting the right clutch in? There are a couple of options at the auto store. 3. The fork seems to have been cut/modified to fit in between the trans and the exhaust. Do I have the wrong fork? 4. I had the return spring attached to the fork and then to a cut hole in the frame. I'm assuming this is in the wrong place. The reason I did this was because the the fork and bearing would not return to the correct position after engaging the clutch. Any advice/help is always greatly appreciated. I'll continue to research as well. Still learning.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
