clutch noise
jahnplay
i got a 2006 GT everytime i shift i push the clutch pedal down then when i shift and let go of the clutch i can hear it engaging the engine. i shift around 2100-2500 but when i shift 3000 RPM it does not make that noise is that normal or is it just me?
Can you better describe the "engaging the engine noise"? Are you talking about the clunk noise heard in the driveline? At lower rpm the clunk noise is present, but at higher rpm the shift changes seem to be smoother. That should be normal and not too much to worry about. Now if you're hearing grinding noises, you should get it checked out.
Can this be the same problem as showtime01 is having?
Plz read his post "Possible transmission/ clutch problems.."
You will find his post on the 1 page couple lines below this post.
Let me know Steve.
