OK here's the problem! my car has been getting harder to shift through the gears! sometimes grinds going into 2nd and once it heats up it gets harder to go through the gears! Ive checked the trans fluid and its full! its a T5 !when it gets hot i have to almost push the clutch through the floor to get it into gear! so i am thinking either time for a new clutch or the cable is pooched!! some other symptoms are when sitting still on a flat surface in gear with my foot holding the clutch down i can kinda feel it grabbing on and off! not enough to make it go forward but enough that i can feel it wanting to go forward! no clutch smells! nothing like that !it a 91 lx 5.0 I'm the second owner of this car no winters on it at all ! and only 130,000 kms = to between 60-70 miles! I'm pretty sure it the original clutch as well as cable! I'm thinking cable and maybe an adjustable quadrant on the firewall might do the trick! but open to other suggestions and thoughts ! thanks
god dam comedian!!
