Wondering if someone could help me determine what my problem is.
Driving home from work today I heard a noise coming from the shifter (was in 5th), I reached down grabbed the shifter and it pulled out of gear while clutch was engaged. I thought maybe I just didn't have it in gear fully, so I put it back in, released the clutch and tried to pull it out, and again it pulled out of gear without depressing the clutch (also tried in 3rd, same result). I think it's probably the clutch since my throw out bearing has been making noise off and on for a little while now. So, like I said, I am assuming I just need to throw a new clutch on it, but wanted to ask to be sure.
Here's my set-up:
Early '01 GT w/ T45
Stock clutch
Tri-Ax shifter (installed about 3 weeks ago)
I would appreciate the input!
Here's my set-up:
Early '01 GT w/ T45
Stock clutch
Ive had to do that before on an old ta I had,clutch was screwed,so I had to shift all gears without a clutch,thats not fun.I did that for about a month,I was young and no money then.
