Clutch Ordering Information
yes... the 10.4 inch disk is generic for 86 to 93. The 10.5 is specific to 93-94. You can still use the 10.5 on earlier fox body's as well (86-95 actually).
Sweet... come back and let us know how the install went. Don't be suprised if you hear chattering for a while after the install. In most cases it goes away after and fairly brief (couple hundred miles in some cases) break-in.
Edit: Oh... and dont' forget to order a new throw-out bearing and pilot bearing. (in case you forgot)
Yeah get the 10.5in. clutch (like you did)...it will fit...the 87-95's use the same flywheel.
I had the same King Cobra you used and noticed no chattering...it is a good clutch and the pedal feel is nice.
This is the part number for the clutch - King Cobra Ford Racing Clutch Kit - #M7560C302
Get your flywheel resurfaced or just buy a new OEM style one, Stock Replacement Flywheel - 397-M-6375-B302
Ford Pressure Plate Bolts and Flywheel Dowel Pin Set - 397-M-6397-A302
The last clutch i had was a spec stage 1 and i didnt like it at all pedal was hard as hell. I even broke it in for a 1000 miles. The new clutch is going on a 306 with heads,cam,intake hope it can hold up.
Yeah Im gona order thoes also. It will be a while befor the break in period cause the motor isnt finished being built
