Clutch parts ?'s
diablostang
425
Raleigh, NC
What parts do I need to replace my stock 95 clutch? I'm going with the Centerforce 1 kit, but I look it up at summit racing, and it has "pressure plates" listed, is that all I need for the clutch?
with the addition of the throwout bearing etc of course, but for the actual clutch itself.
Thanks.
If you are replacing the clutch you will need the pressure plate, clutch disc, T-out bearing, and pilot bearing. The last two are not completely necessary, but if you are in there you might as well replace them. You will also need to have your flywheel resurfaced or replaced if its too thin.
What's done to your car and what clutches are you looking at?
Thanks for the reply, that's what I needed to know. :)
My car is a totally stock 95 GTS, and I'm planniong to put the Centerforce 1 in it. I'm planning to do brakes and suspension and use it as a roadcourse ontrack car.
