clutch pedal assembly
  • Thread starter Thread starter fordmuscle395
  • Start date Start date Oct 1, 2008
fordmuscle395
114
Sumter, sc
Oct 1, 2008
  • Oct 1, 2008
I'm planning on doing an AOD to TKO(5spd) swap and I need the clutch pedal assy...can anyone tell me what year the donor car needs to be?
chobracobra
175
jersey shore
Oct 1, 2008
  • Oct 1, 2008
pretty sure any 79-93 will do for sure. just make sure you get a pedal assembly from a 5.0 car. the clutch quadrant arm on a 4cyl assembly is a lot shorter.
L
LxVert
80
  • Oct 1, 2008
.... and before you begin make sure you are very relaxed and not stressed from anything else... cause soon as you start you will be pulling your hair and ready to throw the car off a cliff or something haha
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Oct 1, 2008
  • Oct 1, 2008
I think early v8 clutches are different too
I'd stick to the 87-93 cars
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Oct 1, 2008
  • Oct 1, 2008
This is the truth. Doing the pedal box on mine was by far the most difficult and time consuming part of the swap.
Beasty306GT
671
Oxford,Mass
Oct 1, 2008
  • Oct 1, 2008
7-UP BILL
885
My other car is a Firetruck
Oct 1, 2008
  • Oct 1, 2008
When I did mine, I replaced the plastic bushings on the pedals. Not sure if they are still serviced by Ford as my car was done 13 years ago. New bushings and synthetic grease and have had no issues. I also reused the AOD brake pedal as it's larger than the T-5's. Works great.
L
lang williams
567
cleveland, oh
Oct 1, 2008
  • Oct 1, 2008
A friend of mine converted an aod cobra replica to a t-5 with out changing the pedals. He swapped in a stand alone clutch pedal with a hydraulic cylinder an hydraulic throw out bearing.
fordmuscle395
114
Sumter, sc
Oct 2, 2008
  • Oct 2, 2008
interesting...I think I'll just stick with the good ol' OEM on this one. I gots step by step instructions with pictures and everything from another website for the assy swap.
fordmuscle395
114
Sumter, sc
Oct 3, 2008
#10
  • Oct 3, 2008
  • #10
new question. can a new Tremec T5 handle a considerable amount of abuse? I see they rate it at around 300 ft/lb...but what are some real world numbers youve seen?
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
WTB Wanted - Foxbody clutch pedal
  • TTSaleen
  • Aug 4, 2026
  • Want to Buy
Want to Buy Aug 6, 2026
General karthief
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
