clutch pedal question
  • Thread starter Thread starter 65notch
  • Start date Start date Mar 5, 2006
65notch
303
661 Cali
Mar 5, 2006
  • Mar 5, 2006
im in the process of installing the clutch/brake pedal assembly into my 65 coupe. im doing a t5 swap so i had to buy a used clutch assembly, i just installed new bushings and spring, but it seems to me the spring isnt correct. when on, it bulls the pedal to the floor...shouldnt it pull away from the floor?
fasttback
471
Northern CA
Mar 5, 2006
  • Mar 5, 2006
Sounds like it's working right. Normally it would be hooked up to the clutch linkage, which would not allow it to go to the floor (unless you want to disengage the pressure plate/clutch = shift). I believe It's the geometry of the pedal arch and spring forces.
Did you have a fun time installing the spring?
fasttback
471
Northern CA
Mar 5, 2006
  • Mar 5, 2006
Sorry, this comment applies to manual linkage. I not sure how this works with cable and hydraulic setups. But with the stock pedal and spring it is working correctly.
65notch
303
661 Cali
Mar 5, 2006
  • Mar 5, 2006
o yeah...i broke one screwdriver and bent another...
D
DJCarbine
392
  • Mar 5, 2006
I cut that spring out from under the dash... after everything gets all worn out it puts everything in a bind and lets the throwout bearing ride against the fingers. Had to replace 2 TOB's
If the bushings and such are new, when you hook everything up it should pull the pedal up (like its supposed to) and also help push it down when you want the clutch in. I dont know how it works, something to do with the spring and linkage geometry, black magic, and the gnomes hiding in my defroster ducts
65notch
303
661 Cali
Mar 5, 2006
  • Mar 5, 2006
u cut the spring out? and it works fine now?
D
DJCarbine
392
  • Mar 5, 2006
http://forums.stangnet.com/showthread.php?t=586648&highlight=Clutch+Spring
Well, mine worked perfectly fine, read the above thread...
The pedal effort increased a little bit, but I like how stiff and lively the pedal is now that I cut it out. The pedal comes up MUCH better, and I got used to it after a week or so. Btw.. I daily drive my car in chicago traffic, so it can't be that bad
I would still go around asking advice on the board, or put everything together and see how you like it with the spring.
LMan
1,246
Mom's basement
Mar 6, 2006
  • Mar 6, 2006
If you are using a cable clutch, you do NOT use the underdash spring.
Dunno about hydraulic.
red65
411
Ann Arbor, MI
Mar 6, 2006
  • Mar 6, 2006
Ditch the underdash spring if you're going hydraulic as well - the clutch master cylinder provides adequate return force. Works fine on mine, anyway (JMC hydraulic clutch).
65notch
303
661 Cali
Mar 7, 2006
#10
  • Mar 7, 2006
  • #10
thanks guys...im doing a cable clutch. ill get rid of that spring right now...
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
