clutch pedal way to high
Dec 5, 2006
153
Clutch ingauges way at the TOP and i can feel the slip is this just a simple adjustment or do i need a new clutch, :( if its a simple adjustment does some 1 have instructions on how to do this , i changed the voltage on my tps sensor also but i dont think this would have anything to do with it would it? jr
Do you have an adjustable quadrant?
I had a simular problem and thought my clutch was toast, it turned out that the cable was getting hung up where it passes through the firewall and was not engaging it as it should. i got a new adjustable clutch quadrant from BBK and have had no probems since.
Also, if you have a manual means of adjustment, try adding more slack to the cable. This will bring the point of engagement down.
Good luck.
Iv done that and it did not help , the clutch pedal is higher that the brake pedal by an inch or so , does this seem normal , iv also been looking into getting the stedda clutch kit , ppl say its a good upgrade so for now ill have a shop set it up just for now then have this kit installed. thanks all
