Clutch preload question with KMC unit
  • Thread starter Thread starter jcode68
  • Start date Start date Jun 7, 2006
jcode68
892
Massachussetts
Jun 7, 2006
  • Jun 7, 2006
Clutch preload question with JMC unit
I posted a question burried in another very old and very long thread without response, so I thought I would try again in a new thread.
I successfully bled the clutch the other night by being patient and following exact steps outline by posts on Stangnet. After 5 or 6 refills of the resevior, I think I got it completely bled. Pedal feels firm, starts to engage about 1/4th of the way down and the fork travels about an inch or slightly more (didn't measure it).
So now my question/problem: The rear is up on jack stands so to adjust the clutch preload, I used the following method. I first adjusted preload to just have tentsion on the pressure plate fingers. I started the car, put it in first gear, tires were spinning, I pushed clutch pedal fully and slowly applied the brakes. Problem is, this caused the car to stall, so the clutch is obviously not disengaging fully. I continued to adjust the preload several times until I could apply the brake and stop the wheel without stalling. I'm concerned that I have overadjusted and put too much preload and don't want to burn my clutch out. I have the JMC, not a home made unit (not that there is anything wrong with that approach) and the preload is currently adjusted almost all the way to the end of the adjustment. Questions? How much travel should I have with the fork when the clutch is fully bled? How much adjustment do you have left in your setup? Is yours near the end like mine? Is the way that I am testing appropriate or is there a better way? I have the car going to the exhaust shop on Thursday, so I would like to get this working before then.
<!-- / message --><!-- google_ad_section_end --><!-- sig -->
jcode68
892
Massachussetts
Jun 7, 2006
  • Jun 7, 2006
That makes sense and in line with what I thought. I guess I will bleed, bleed, bleed this thing. I can't believe how difficult a system this has been to bleed. Nice clean install, but bleeding is a Beeatch!
jcode68
892
Massachussetts
Jun 8, 2006
  • Jun 8, 2006
blkford, this is a great tip, wish I knew sooner
I actually went back and bled it some more last night and it is now working fantastic! Getting full travel and I was able to properly adjust the clutch preload so I won't risk burning up my new King Cobra clutch. I think JMC should consolidate all the various information from Stangnet threads on their product and rewrite the documentation. Their instructions are completely horrible! Thanks again for the responses, hopefully I am done messing with the clutch now!
180 Out
375
  • Jun 8, 2006
I agree, it's almost comical how often it comes up in the forums, that people can't get their hydraulic clutch setups fully bled. It seems like the usual advice is, when you think you're done, you're not!
The method for setting preload that McLeod puts in its hydraulic TO bearing instructions, is to have the car on a slight incline and set the preload so the car will roll when in gear when you declutch, with the engine not running. Makes sense.
69Rcode_Mach1
1,473
Salt Lake City, Utah
Jun 9, 2006
  • Jun 9, 2006
blkfrd said:
I had trouble at first too. Then did the following and it bled in minutes:
You need a helper to press the pedal
Open the bleeder screw while pressing on the piston and push it slowly until it seats. Tighten the bleeder screw. Pull the piston out slowly with something that can hook onto the inside edge of the piston until it is flush with end of the cylinder and don't scratch the cylinder. Loosen the bleeder screw while pushing on the piston and push it slowly until the piston seats. Pull the piston out again and re-seat it using the previous steps. This procedure will draw fluid out of the master and resevoir and help a lot to bleed the system. Refill the resevoir and do it a few more times if you want.
Reseat the piston and refill the resevoir and have the helper press on the pedal and see if the piston moves all the way until its just about flush with the end of the cylinder. You can push on the cylinder while the helper depresses the pedal to be sure the piston feels solid and not spongy.
Your done.
Blkford I am a little confused on your instructions. I need help too, because everytime I think I have it bled properly it turns out that I don't. Are you saying to have someone push on the pedal from inside the car, open the bleeder, then push into the slave by handwhile someone is pushing on the pedal? I am just putting the image together in my head incorrectly. Care to clarify on the part on the hydraulic slave unit? I don't know what the piston is, sorry to hijack, but I have been driving with an improperly bled clutch which is probably frying my clutch.
C
C0V3R
524
Australia
Jul 10, 2007
  • Jul 10, 2007
Guys, how much travel do you get at the clutch fork? I am struggling to get a hydraulic setup going and need to know how much travel is needed.
Thanks.
jcode68
892
Massachussetts
Jul 10, 2007
  • Jul 10, 2007
Give this thread a birthday cake
You should have about 1.5" of travel if I recall correctly. The best way to check for full travel is by looking at the piston on the slave cylinder to ensure it is traveling to the end of the sleeve. Just pull the rubber boot back and you should be able to get a good look at it.
C
C0V3R
524
Australia
Jul 10, 2007
  • Jul 10, 2007
Can you tell how desperate I am by how far back I have been searching?
Ahh crap I have nowhere near 1.5in.
I knew I should have just gone with the jmc kit instead of cobbling it together. I could have paid for it about 50x over by now with wasted time & parts.
If anyone else knows for certain how much travel there is please post!
jcode68
892
Massachussetts
Jul 10, 2007
  • Jul 10, 2007
Have you seen this site yet:
http://midnightdsigns.com/Mustang/HYD Clutch.htm
This guy assembled his own kit and did a great job documenting the install etc. Maybe this helps. What pieces are you using?
C
C0V3R
524
Australia
Jul 10, 2007
#10
  • Jul 10, 2007
  • #10
Yep I've seen it. I am using compeltely different parts due to availability.
Using a tilton 75 series 15/16 master with 1.1 in stroke (first mistake)
I have tried a 3/4 slave (really heavy clutch actuation, gives quite a lot of stroke) from a local falcon
Also tried a 1 1/8 slave from a peugot 505 to restore the hydraulic ratio to what it should be stock. This made the pedal feel quite good, but the short stroke of the master seems to have left me without enough disengagement travel.
I haven't been able to find anywhere that says definitively how much travel is required which leaves me guessing as to what the dimensions of everything need to be.
I haven't had time to swap back in the 3/4 to measure the disengagement distance there yet, as I have to make up new hard lines (again).
jcode68
892
Massachussetts
Jul 11, 2007
#11
  • Jul 11, 2007
  • #11
Wow, seems like you have a lot of time tied up in this project, not to mention the costs of parts. If it were me, I would cut bait mate and just by the JMC kit. It's really a plug & play deal and the hardest part is bleeding the damn thing. Otherwise it's a piece of cake to install and performs very nicely. It's a bit pricey at $450, but at least you know it will work when you are done
Markus
238
germany
Jul 11, 2007
#12
  • Jul 11, 2007
  • #12
Hello guys,
i have the jmc system too. First i had the same problem to disengaging fully the clutch.
So i take a guestion at jmc. Here is the correspondence:
> Dear Sir,
i use your hydraulic clutch kit for my 67 fastback with a tremec tko.
Now my question. In the installation instruction you say, i must set a
slightly preload at the throw out bearing.
I use a new tob from centerforce. My clutch is a centerforce dual
friction.
Other clutch manufacturer say, don´t set preload to the tob because it does spin permanetly and does not last long.
The tranny shift only perfect if i set a light preload. I set the preload with my fingers not a wrench.
Is that ok? If not, what can i do?
Markus Becker <
The answer:
Hello Marcus,
Thank you for using our hydraulic clutch kit in your vehicle.
First, we will need to measure the stroke of the slave cylinder to see
if you have properly bled the hydraulic system. The maximum length
the slave cylinder will travel is 1 1/4" (1.25"). Have someone in
the vehicle and press on the clutch pedal. If you are getting the
maximum travel, then call Centerforce and see if you can put some
pressure on the clutch fingers. If you need more travel from the
slave cylinder, we have an upgraded slave cylinder that has a maximum travel of 1 3/4" (1.75"). This slave cylinder is priced at $139.95.
If you have any more questions, please give us a call or send us a
message back. Thank you for your time.
Steve @ JMC Motorsports<
So i take a question to centerforce:
>Dear Sir,
i use a centerforce dual friction in my 67 mustang (5.0 engine). Also i
use a hydraulic clutch linkage. Now my question. The shifting with my
tremec tko is only perfect, if i set a slightly preload on the throw out
bearing. The tob i from centerforce too (#N1714). Is that a problem?
thank you very much
Markus Becker<
The answer:
>Hello, Markus.
When using hydraulic linkage they are designed to apply (preload) to the
clutch assembly. I do not for see a problem with this install.
Sincerely.
Brian Hankla
Tech Support
Centerforce Clutch
928/771-8422 X-36<
Now i give a little preload and the shifting is very easy. But check the
correct travel from the slave cylinder.
I hope that help a little.
Markus
C
C0V3R
524
Australia
Jul 12, 2007
#13
  • Jul 12, 2007
  • #13
Swapped back to the heavy clutch setup. Looks like I need about 5/8-11/16 of throw to disengage the clutch with no linkage. I am getting a little over 1 1/8 in throw in total.
Hopefully I can tweak the bore ratios a little to take this into account. Also working on the idea of using a bell crank to get more mechanical advantage.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
Need a clutch, 1982 Capri RS 5.0 owner, am I allowed to participate?
  • scudzuki
  • Apr 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2025
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
