Clutch preload question with JMC unit
I posted a question burried in another very old and very long thread without response, so I thought I would try again in a new thread.
I successfully bled the clutch the other night by being patient and following exact steps outline by posts on Stangnet. After 5 or 6 refills of the resevior, I think I got it completely bled. Pedal feels firm, starts to engage about 1/4th of the way down and the fork travels about an inch or slightly more (didn't measure it).
So now my question/problem: The rear is up on jack stands so to adjust the clutch preload, I used the following method. I first adjusted preload to just have tentsion on the pressure plate fingers. I started the car, put it in first gear, tires were spinning, I pushed clutch pedal fully and slowly applied the brakes. Problem is, this caused the car to stall, so the clutch is obviously not disengaging fully. I continued to adjust the preload several times until I could apply the brake and stop the wheel without stalling. I'm concerned that I have overadjusted and put too much preload and don't want to burn my clutch out. I have the JMC, not a home made unit (not that there is anything wrong with that approach) and the preload is currently adjusted almost all the way to the end of the adjustment. Questions? How much travel should I have with the fork when the clutch is fully bled? How much adjustment do you have left in your setup? Is yours near the end like mine? Is the way that I am testing appropriate or is there a better way? I have the car going to the exhaust shop on Thursday, so I would like to get this working before then.
<!-- / message --><!-- google_ad_section_end --><!-- sig -->
