Clutch problem ??? HELP
  • Thread starter Thread starter sctops140
  • Start date Start date Jul 31, 2006
sctops140
  • Jul 31, 2006
I have a 94 GT. When my clutch pedal is out, my car is making more of a ticking sound rather than a squeaking sound. You push the clutch in about half way, and the sound goes away. You look underneath the car and you can see the clutch fork is vibrating I guess. You can put slight pressure on the clutch fork and the sound goes away. Does anybody know what the problem is? I've put a new throwout bearing, steel bearing retainer, and adjustable cable setup...and the problem still exists. The clutch was relatively new when I bought the car. Could it be the clutch fork? The car has a blower, if it's a heavy duty clutch, could it be too much for the stock clutch fork? Help?? Anyone?? Much appreciated. --Sean
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jul 31, 2006
  • Jul 31, 2006
Did you notice any wear on the inside of the bellhousing, flywheel, pressure plate, or the backing plate? I haven't heard of the clutch fork needing replaced because of a high performance clutch usually just because of special bellhousing. What throwout bearing did you put in it?
HISSIN50
34
129
Jul 31, 2006
  • Jul 31, 2006
Is there slack in the cable right now?
SPEEDYLIFSAVR
666
FL,89 LX 5.0
Jul 31, 2006
  • Jul 31, 2006
Are you sure you have the TOB oriented in the clutch fork correctly? There is a little clip it fits into .
sctops140
  • Jul 31, 2006
I put a For Racing TOB in, got it from summit, along with a steel front bearing retainer for trans. Didn't notice anything unusual. Yes, TOB is on the fork correctly. Any other ideas?
sctops140
  • Aug 1, 2006
Help!!
ninety15.0
1,336
  • Aug 1, 2006
I had that happen to me and i replaced the TOB...about 1500 miles later the same thing happened. So i put a new TOB in and it hasnt come back since. Sometime you just get a bum TOB. Sorry man...i know what squeeking is anoying as hell. Oh..you could also adjust some of the clutch cable slack out...that might help
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
