  • SN95 4.6L Mustang Tech
Clutch Problem/Question
  • Thread starter Thread starter EmperorXII
  • Start date Start date May 17, 2004
E
EmperorXII
51
Cincinnati, OH
May 17, 2004
  • May 17, 2004
Here's the problem I'm having, the car (2000 GT) makes this weird, rapid squeaking-type noise a lot of the time while driving or even at idle and when I put my foot on the clutch, the noise stops. Any ideas?
85GTlover
704
  • May 17, 2004
Throw out bearing probably. you will need to have the tranny dropped, likely a new clutch, get out your wallet.
ImportEater98
708
Worcester, MA
May 17, 2004
  • May 17, 2004
Throwout bearing...or if you are lucky its just the clutch fork hitting the bellhousing (or rubbing). That was my problem. Check for free fixes before you pull out the wallet, drop your pants, and clinch the pillow.
M
markweb
  • May 18, 2004
I would rule out a throw out bearing, because if you remember, the bearing spins when you step on the clutch and the input shaft of the tranny dosn't. if the noise goes away when you step on the clutch it usually something with the tranny.
02bigdaveGT
45
North Carolina
May 18, 2004
  • May 18, 2004
My 02 does the same thing. I thought it was just the noisy throw out bearing that a lot of 3650's have a problem with. The clutch seems to work fine, so I'm not gonna worry about it until something breaks.
Tylerb59
Banned
Mar 7, 2003
1,895
Arlington, WA
May 18, 2004
  • May 18, 2004
It's the throwout bearing.
$30 part, just takes a bit of work to get to it and this is usually when people replace clutches simply because you're down there. You don't have to though, but if you're close to or over 60k miles I would.
Going in this weekend to replace my TOB, it's starting to squeal again. (sounds like crickets)
02bigdaveGT
45
North Carolina
May 18, 2004
  • May 18, 2004
Good point, since my car has 50K I probably should change mine. How much does it cost to get it replaced?
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Dudes... Who do I gotta kill?
  • Noobz347
  • Jul 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 22, 2026
LILCBRA
