CLUTCH PROBLEM
  • Thread starter Thread starter SHEIMERL
  • Start date Start date May 5, 2004
SHEIMERL
  • May 5, 2004
1. HOW DO I REMOVE THE PILOT BUSHING (AT FLYWHEEL)FROM MY 1967 6 CYLINDER 3 SPEED COUPE.
2. THERE IS A BRACKET ON THE BELL HOUSING FOR THE SHIFT LEVER. ITS BROKEN, WHERE DO I GET A REPLACEMENT AND HOW DO I INSTALL IT?
THANKS,
STEVE
C
cfauvel
86
Sarasota,Fl
May 6, 2004
  • May 6, 2004
how to remove the pilot bushing
Autozone has a service where you can use their tools for free with a security deposit.
What you need is a "pilot bushing" removal tool...they have them.
looks like a gear puller but the claws are pointing outward, slip the tool into the hole of the bushing, tighten the tool to get the claws snug against the bushing and use the slide hammer to get it out.
Use the proper tool to put the new one in.
R
Ronstang
1,294
Houston Texas
May 6, 2004
  • May 6, 2004
To get pilot bushings out that you don't need to reuse I simply find the appropriate size tap and run it into the bushing (threading it) until it bottoms out on the back of the crank.....then I proceed carefully until the bushing simply pops out.
LMan
1,246
Mom's basement
May 6, 2004
  • May 6, 2004
if its a bronze bushing, I have also used a Dremel to cut them into a piece or two and remove the pieces.
D
D.Hearne
11,730
south louisiana
May 6, 2004
  • May 6, 2004
What? Everyone's forgot about the "grease packing method"? Or just afriad to get your hands dirty?
K:^P
67
OCCal/BACal
May 6, 2004
  • May 6, 2004
I used the grease method too once. Pack the grease into the hole, shove the clutch alignment tool into it, and the bushing should pop out. Hydraulics.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Yesterday at 6:01 PM
Rcdgl
R
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
