DTNODYA said:
This is an informative post. Let me see if I understand ... you are saying that pulling up with your foot RESETS the cable to wherever it is currently? So if I do what you did, does that mean that there is constant pressure on the bearing (slight pressure)?
Reason I ask is because my TOB has been chirping/squeaking and what not for a while. I got under the car the other day and took the little plate off where you can see your TOB and it is in tact and LOOKS fine. If you hold very slight pressure on the 'arm' (don't know what it's called) that pulls the TOB when the clutch is pressed the chirping stops. Or, if you just barely apply the smallest bit of pressure on the clutch pedal (i'm talkin' just touch it) the noise goes away too. Should I just adjust it the way you described? I don't really understand with the hammer end though but I guess I'll read the (worthless) Haynes ...
Yes, if you do what I did you are increasing the tension on the cable slightly which is in turn applying that pressure to the bearing. Same thing as you putting slight pressure on the pedal with your foot to stop the noise.
Saftey first.Turn the car off, set your parking brake and make sure the car won't roll if you push the clutch pedal in.
Slide your drivers seat all the way back. The only tool you need is a hammer. I used a hammer because it gave me more reach and leverage. You could use anything really, It was too awkward to just use my hand.
Look under the dash and find the quadrant above the gas pedal, it is white plastic. If you don't see it, push in the clutch pedal with your hand and you will see it rotate.
The quad will have a plastic hook looking thing sticking out on the bottom. Right next to the hook is a large flat spot. The flat spot is where you will put the end of the hammer handle.
Place your left hand on the clutch pedal, and the hammer end on the flat spot of the quad. Slowly push the pedal in, the quad will rotate so keep your hammer on it. Now slowly let out on the pedal while keeping steady pressure on the quad with the hammer (let the pedal do the work, don't push the hammer too hard). You should hear and feel the quad click as the pedal comes out and the hammer pushes up. When it clicks once remove the hammer from the quad and let the pedal out.
Start the car and see if the squeaking is gone. If not, adjust it another click. If you go to far, pull up on the pedal with your toe and push it back in. You will be back where you started.
Like I said, I don't know if this is worse for the bearing than letting it squeak. I have always heard that you want a little bit of play in the pedal before you have to put any real pressure on it. In other words don't tighten it too much and put too much pressure on the bearing.
