Clutch problems and fluid question
  • Thread starter Thread starter 87lc2
  • Start date Start date May 31, 2006
87lc2
214
May 31, 2006
  • May 31, 2006
Have a motorsport clutch that i put in when i got the car about 6 months ago. when cold, its a dream, lets up about halfway from the floor and has a good feel. however, when hot it gets much stiffer and and barely lets up at the floor! i have to press it through the floor it seems just to shift. i checked out the cable and its fine, although the mounting bracket to the frame was snapped off. i replaced the bracket and its a little better, but still horrible when hot. What could this be? its really becomeing a PITA! also, when changing the fluid i used dexron III as stated in the manual and on here, is that correct? TIA
HISSIN50
34
129
May 31, 2006
  • May 31, 2006
Is the clutch cable near the headers (the snapped bracket and heat-related comments really made me wonder)? If not the issue now, the cable might have gone south already from heat.
Good luck.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 31, 2006
  • May 31, 2006
yea the cable would expand in the sleeve from the heat off the header......makes sense to me
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 31, 2006
  • May 31, 2006
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 31, 2006
  • May 31, 2006
sorry for the DP my computer suxass
87lc2
214
May 31, 2006
  • May 31, 2006
Yes, i have aftermarket headers and they stick out further than the stockers. when i realized the bracket was broken, the cable was less than an inch away from them. i figured it was ok because there was no external damage to the cable. it is much much better now that it is mounted correctly away from them. however, you are probably right in that the damage was already done. question is, what the best bet for a replacement cable? autozone has them for around $30, but that seems to inexpensive. the ford dealer can order on for somewher over $200!!! thats insane. is there any stock style replacement thats known to hold up well and not cost a small fortune?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 31, 2006
  • May 31, 2006
go with a bbk or steeda one and replace the old clutch quadremt while u are at it.
HISSIN50
34
129
Jun 1, 2006
  • Jun 1, 2006
Opinions will differ - I got a non-adjustable OEM style cable from Diversified - 50 bucks to my door.
Good luck.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 1, 2006
  • Jun 1, 2006
I'll sell ya a UPR tripple hook quad and a UPR firewall adj
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 1, 2006
#10
  • Jun 1, 2006
  • #10
[/IMG]
215what
154
NM
Jun 1, 2006
#11
  • Jun 1, 2006
  • #11
Stock cable is the best!!
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
M
  • mnky99
  • Sep 5, 2025
mnky99
M
