Clutch Problems
  • Thread starter Thread starter TwoToneHatch
  • Start date Start date Nov 10, 2009
TwoToneHatch
170
New Jersey
Nov 10, 2009
  • Nov 10, 2009
So I got done my T5 swap and I jumped in the car to test drive it.Well I was in neutral and I pushed the clutch in and released it and on the release it made this really creep noise and even with the clutch pushed in it wouldnt go into gear.I was under the car and noticed the fork had zero play at all and only travelled maybe half way up the hole it sticks out of.I took it back apart and everything was installed correct.Well The clutch disk never made contact with the flywheel at all they both have no marks,signs of wear nothing the clutch disk still has the fully intact little painted logo.
A friend of mine said to take just the pressure plate without the clutch disk and blot it up and check for play well there's about an 1/8th inch of play when I do that. Can anyone help out I feel bad having to borrow someone's car since mine is obviously down.
Thanks in Advance!
stangfanatic
107
Martinez, Ga
Nov 10, 2009
  • Nov 10, 2009
What kind of clutch is it? And I can only assume you got parts from a junkyard or used to do your swap, you sure the clutch fork is not bent? Also, did the throwout bearing go on easy (slide on the shaft) and did you install it on the fork in the right direction... I know, its a stupid question, but I've seen some things done that shouldnt have been possible.
stykthyn
5,232
2,652
223
gainesville
Nov 11, 2009
  • Nov 11, 2009
how hard was it to get the pedal to the floor? it almost sounds like you were stretching the cable and its not quite long enough to disengage the clutch.
TwoToneHatch
170
New Jersey
Nov 11, 2009
  • Nov 11, 2009
Everything besides the bellhousing,the fork and the trans itself is brand new. I have all ARP hardware,new zoom clutch and flywheel,etc. The pedal was pretty stiff but it went up and down fine. And i;m pretty sure the fork is straight and installed right,the throwout bearing was fine?
stykthyn
5,232
2,652
223
gainesville
Nov 11, 2009
  • Nov 11, 2009
do you still have the self adjusting pawl or an aftermarket quad?
TwoToneHatch
170
New Jersey
Nov 11, 2009
  • Nov 11, 2009
I have A BBK clutch cable,firewall adjuster,and quadrant.
D
DonMaximo
217
Lewisville, Texas
Nov 11, 2009
  • Nov 11, 2009
In the least, there are 2 spots where the clutch cable can hook to the quadrant on the interior.
Check to see if you jumped on the first/(most forward) slot. This could explain why the clutch is not being fully disengaged.
If so, you'll want to consider unfastening/loosening the cable at the clutch fork, so you can pull the other end (interior) of the cable rear-ward to the quadrant slot furthest away from firewall.
Hope this makes sense.
Afterwards, go back under car and tighten down cable to clutch fork, accordingly.
You didn't indicate if you replaced the clutch cable...
Best Regards.
-D
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
Should I Get a New Clutch Fork and Pivot Ball Stud?
  • AeroCoupe
  • Dec 18, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2022
96pushrod
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
