Clutch Question, and Error code 31 question
  • Thread starter Thread starter Killerrobotjews
  • Start date Start date Dec 31, 2004
K
Killerrobotjews
62
  • Dec 31, 2004
So my stock clutch cable self adjuster is not working, and it was suggested that i get an aftermarket quadrant and FWA. can someone link me to everything i would need for this part wise?
Also, Checked the codes on my stang and got a 31. what does this mean and how do i fix it?
Thanks!
D
Daggar
3,902
  • Dec 31, 2004
Here... I'll link you to the one I just ordered.
http://www.maximummotorsports.com/cq.asp
K
Killerrobotjews
62
  • Dec 31, 2004
Cool, will i need a new cable with it?
K
Killerrobotjews
62
  • Dec 31, 2004
err sorry, if i buy the whole clutch kit, i should be set right?
K
Killerrobotjews
62
  • Dec 31, 2004
Alright, so if i order MMCP-51 the cables universal and will work in my '90 correct?
K
Killerrobotjews
62
  • Dec 31, 2004
Anyone have an answer for the code problem?
D
Daggar
3,902
  • Dec 31, 2004
yes... get the whole kit with the universal cable. It's already modified and ready to be installed.
K
Killerrobotjews
62
  • Dec 31, 2004
Awesome, Just ordered it Thanks!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 31, 2004
  • Dec 31, 2004
CODE: 31 (KOEO) - EVP circuit below minimum voltage. Vref (5 volt reference voltage supplied by the computer) missing or broken wire or bad connection in circuit. Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or MAP sensor located on the firewall near the center of the car. Use the black/white wire for the ground for the DVM.
With the sensor removed from the EGR and still connected, press the plunger and watch the voltage change on the brown/lt green wire. Pull the passenger side kick panel and measure the voltage at the computer. You will need to remove the plastic cover over the wires and probe them from the backside. A safety pin may prove very useful for this task. Use pin 27, EVR input (brown/lt green wire) and pin 46, signal ground (black/white wire) to measure the voltage. The orange/white wire is Vref and should always be 5 volts -/+ .25 volt. Be sure to measure Vref at the EGR sensor to rule out any broken wires or bad connections.
K
Killerrobotjews
62
#10
  • Dec 31, 2004
  • #10
So code 31's not a critical problem right?
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
