EXTRPR50 Founding Member Oct 7, 1998 370 1 19 Jul 31, 2004 #1 Jul 31, 2004 #1 I am putting a '90 roller motor in my '84 gt. Do I use the 10.5" clutch the '90 uses, or the 10" clutch the '84 tranny uses? I will be using the the '84 t-5 tranny, and I have the flywheels for both engines. Thanx
S ss93cobra Founding Member Apr 10, 2002 1,422 1 0 Wilmington NC Jul 31, 2004 #2 Jul 31, 2004 #2 Well, I don't know for certain, but I can tell you that both use the same bellhousing which means that the 10.5 clutch should fit in your bellhousing and that the transmission should fit as well. I hope this helps a little bit at least.
orangecapri New Member Dec 16, 2002 189 0 0 Alden, KS Jul 31, 2004 #3 Jul 31, 2004 #3 use the 10.5" clutch with the '90 motors flywheel.
S SlowGT Founding Member Jun 17, 1999 826 0 0 Columbia Co, PA Jul 31, 2004 #4 Jul 31, 2004 #4 I agree with the orangecapri
stangbear427 Active Member Nov 11, 2002 2,401 1 49 New England Jul 31, 2004 #5 Jul 31, 2004 #5 and I agree with both of them. Use the bigger one.
