  • 2005 - 2009 Specific Tech
Clutch question?
  • Thread starter Thread starter LNOR
  • Start date Start date Apr 2, 2007
LNOR
10
  • Apr 2, 2007
OK clutch experts. The clutch on the 07 GT is hydraulic without any way to adjust the point at which it engages, or so my dealer tells me. My son and I both have 07 GTs. Mine starts to engage about 1/4 off the floorboard while my son's doesn't start to engage until almost 2/3 off the floor. Why does a self adjusting system differ so much between two supposedly identical vehicles? Has anyone figured a way to adjust clutch pedal travel without dropping the trans and shimming the throwout bearing?
Any input will be appreciated
C
"car"azy
40
  • Apr 2, 2007
tell them to bleed it, its a pain i did mine when my intake was off and it was still hard to get to it seemed to help alittle
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 3, 2007
  • Apr 3, 2007
Bleeding may fix that, if not they might have to repalce the clutch master cylinder.
metroplex
405
SE MI
Apr 5, 2007
  • Apr 5, 2007
How do you bleed the hydraulic clutch system on the 05-up GT? I didn't see any mention of a bleeder screw for the slave cylinder.
My clutch pedal has to be 2/3 from the floor for it to engage, which is somewhat a PITA coupled with the laggy drive by wire.
anthony05gt
1,262
Maryland
Apr 6, 2007
  • Apr 6, 2007
There is a bleeder fitting at the slave cylinder, but you do not have to bleed it there or use a vacuum pump. Just jack up the driver's side of the car about 10'' or so and very slowly pump the clutch pedal in and out for about 5 minutes. That will completely rid the system of all air. You have to pump the pedal very slowly though because if you don't the air doesn't have the chance to escape through the port in the master cylinder. The difference between your son's car and your's may be because of non-exacting tolerances between all drivetrain parts, master cylinder freeplay and a host of possibilities.
Jizabel
N. Florida
Apr 7, 2007
  • Apr 7, 2007
06 and newer doesn't have bleeder valve, use a vac pump on master cylinder 15in for 1 min,. Or just jack driver side and slowly pump pedal for 5 mins, if u do it fast it just airates the fluid.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
T
Mcleod Hydraulic Clutch
  • TheJay806
  • Apr 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2025
limp
Engine 88 5.0 clutch engagement seems wrong.
  • 1yesfan
  • Apr 13, 2025
Fox 5.0 Mustang Tech Apr 13, 2025
1yesfan
