Thowout Bearing question!
When the clutch pedal isn't engaged should the TO bearing still spin? I heard that there should be about 1/8" to 1/4" play between the TO bearing and the Pressure Plate. Because of the cup like recess in the Pressure Plate center (where the TO bearing rests) I can't measure the gap because the TO bearing is resting in that gap! The Pressure Plate fingers don't look like they are engaged but yet the TO bearing spins wether cluch is pushed in or not, is this normal (or could the bearing be spinning because of friction)??
If the TO bearing isn't suppose to move at all while clutch is disengaged, how can I get enough play at the clutch fork to move the TO bearing slightly away from the Pressure Plate (the self adjusting quadrant automatically adjusts to this setting) ??
I have messed with this all weekend to get some free play and I can't get any (I even tried a new OEM cable)!
B.T.W: The car shifts fine, no grinds and when clutch is pushed in gear engagment is butter smooth, I want to make sure i'm not wearing out my TO bearing because of it spinning!!
Thanks for the attention!!!
Little History.....
Been playing around with a squeaky clutch pedal for about a week now! Posted on here before about this and was told possible TO bearing. This may be the case although I have my doubts because of the noise that it's making!
The noise is only present while the pedal is on it's enaging stroke (inward towads floor). When the pedal reaches the floor no noise is present (TO bearing should squeel with pedal on floor). So this noise seems to me to be coming from the cable or stock quadrant! Also note that the noise doesn't happen all the time (it will do it for like a minute, then won't make a peep again for sometimes 1-5 mins). I'm thinking either cable or Quadrant.
Little History.....
