Clutch Setup or tranny problem?
  • Thread starter Thread starter riceeater87
  • Start date Start date Mar 10, 2006
R
riceeater87
59
hamburg, nj
Mar 10, 2006
  • Mar 10, 2006
I am having trouble shifting my car during normal driving. But during hard shifts at higher rpm's it shifts fine. The trans is a TKO 600, clutch is a Spec stage 2, have an adjustable cable and firewall adjuster. Do i have a clutch adjustment issue or a synchro problem with the tranny? Everything was brand new when installed and has about 700 miles on it now. Thanks in advance for the help.
HISSIN50
34
129
Mar 10, 2006
  • Mar 10, 2006
Does it do it in all gears?
Did you use the right fluid for the trans?
Good luck.
R
riceeater87
59
hamburg, nj
Mar 19, 2006
  • Mar 19, 2006
yeah it will do it in all gears. i am using the same exact fluid as my buddy, which is the GM friction modified stuff, with the same trans and his shifts fine.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Mar 19, 2006
  • Mar 19, 2006
I determine slipage this way: drive down a long section of road or highway (at the speed limit) in 5th or 4th gear. Without shifing, apply the gas to accelerate. If the speed increases with the RPM's than your clutch isn't slipping. If your RPM's go up without an increase in speed than your clutch is slipping.
This might help you diagnose your problems.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 19, 2006
  • Mar 19, 2006
one way to tell if you have enough clutch air gap for good clean shifts is from a stop hold the clutch all the way to the floor and in first gear slowly let out untill you see the rpm's start to drop, you should have lifted your foot at least 1-2 inches before it started to drop. If it is less than that you need to tighten your clutch cable a little.
M
Mike92GT
583
Florida
Mar 20, 2006
  • Mar 20, 2006
It sounds like you need to tighten up your clutch cable a little bit, just don't over-do it.
blackcloud50
388
  • Mar 20, 2006
clutch should engage approx 1/3 the way up of full pedal travel from the floor floor
R
riceeater87
59
hamburg, nj
Mar 20, 2006
  • Mar 20, 2006
i will try adjusting the cable next time i take the car out. the pedal is also very stiff, much more so than my buddies with same set up, any areas i should look for cable bind?
HISSIN50
34
129
Mar 20, 2006
  • Mar 20, 2006
Misrouting of the cable itself can cause binding or tough travel. You want the cable to make a sweeping arc. And check the cable near the headers (esp if you have LT's) for sheath damage.
Good luck.
V
v8only
2,378
22
49
Mar 21, 2006
#10
  • Mar 21, 2006
  • #10
agreed, before even adjusting, i'd check routing. make sure it's poked under the dr side motor mount bracket
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
