  • SVT Tech Forum
clutch took a dump.
  • Thread starter Thread starter stang dreamer
  • Start date Start date Jul 20, 2008
stang dreamer
Manchester, UK
Jul 20, 2008
  • Jul 20, 2008
hey guys, the SVT clutch took a crap at around 5pm yesterday, driving along it was fine, until it come to stop, then when we restarted it the clutch felt completely different and made the most horrific noise i have ever heard. screeching like hell.
question is, i have found two different clutches on ebay, one says 10 spline, other says 28 spline, whats the difference, and which do i need? the car was built on the 5th dec 97, i heard that theres two different boxes as borg warner was taken over by tremec sometime during the 98 model year, this true?
would i have to worry about the box, or is it just the clutch thats had it?
stang dreamer
Manchester, UK
Jul 21, 2008
  • Jul 21, 2008
no help?
heres a video of what has happened...
VIDEO0011.flv - Video - Photobucket - Video and Image Hosting
sounds V serious, is it possible that the box is damaged or is it just clutch?
cobradude
Maryland
Jul 21, 2008
  • Jul 21, 2008
It sounds like the throw-out bearing is shot. If you change it right away, you might get lucky and only need the bearing. If you keep running it, the pressure plate will be destroyed also. I really don't know about the spline question. I depends on which transmission you have. Can you find a tag on it?
T
tritonofg
36
San Diego
Jul 22, 2008
  • Jul 22, 2008
transmission
Your car came w/ a T-45 but that does not mean you still have a t-45 (unless you are the original owner and know every mod)...
If it it a t-45 tansmission that has never been cracked open it should have a small metal tag on the tailhousing..
P
Price1
109
Dryfork, WV
Aug 10, 2008
  • Aug 10, 2008
All stock clutches are 10 spline; any other input spline count is aftermarket. Don't forget to get the flywheel surfaced and replace the pilot bearing, which can be a pita.
Good luck.
P
pawelzajac
  • Aug 11, 2008
your throwout bearing is most likely shot and i also had to replace the forks inside that push on them i believe. Yea.. same thing happend to me thank God i was like 4 blocks away from home. it started screeching, i thought that i broke a rod or the piston was scratching the sleeve. As for the spline i really cant tell you. But you'll be fine goodluck with the fix.
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
J
  • JRC99
  • Apr 19, 2025
JRC99
J
SOLD 1993 Mustang Cobra / 114K miles / Modified / Fort Lauderdale, Florida.
  • Naja
  • Oct 4, 2023
12K
Fox Body Mustangs For Sale (1979-93) Feb 26, 2025
Naja
  • SVT Tech Forum
