  • 1994 - 1995 Specific Tech
clutch/tranny problem
  • Thread starter Thread starter veryslow5point0
  • Start date Start date Jun 8, 2009
V
veryslow5point0
36
Pennant, sask, canada
Jun 8, 2009
  • Jun 8, 2009
Well I decided to get the stang out today after it has been sitting for a few years. Good news is that after i checked the fluids and went to start it, the car had barely turned over and it was running like a dream, but the bad news is that I cant get the car to go into any gear when I push the clutch in. I managed to get the car started in gear and drive it around. Even after this, when I push the clutch in, it does not engage and the car will still drive. Anyone have any ideas of whats going on or what to do? Sorry for the long post and thanks in advance!!
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jun 8, 2009
  • Jun 8, 2009
Well, it's definately the clutch. Start with the cable. Check to see if the fork moves when you press in the clutch. If it does, then you need to pull the tranny and check the clutch out.
Kurt
V
veryslow5point0
36
Jun 8, 2009
  • Jun 8, 2009
when i push the clutch i can feel it pull so I kind of think that the cable is ok, but I will definatly check the cable. Is it possible that the clutch plate has seized to the flywheel?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Jun 9, 2009
  • Jun 9, 2009
I had that problem with my Cobra clone, although I had used an aftermarket clutch cable, quadrant, etc (Maximum Motorsports kit). My cable simply wasn't pulling far enough on the clutch to disengage it. Do you have an adjustable firewall adapter? Or an adjustable cable?
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jun 9, 2009
  • Jun 9, 2009
Doesn't sound too realistic. Maybe the pressure plate just gave up the ghost. Or a spring rusted out of the disc. Hard to say, you just have to get in there and look at it.
Kurt
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
