  • SN95 V6 Mustang Tech
Clutch Trouble???
  • Thread starter Thread starter Iggy50
  • Start date Start date Jul 14, 2005
I
Iggy50
  • Jul 14, 2005
Hi all, another newbie here.
Been having trouble ****ing into 5th gear. Seems like the clutch isn't fully disengaging and causing it to grind.....sometimes.
Stang is an '02, 3.8L, with 33k on the clock.
First thing I thought of was the trans might be low on fluid. Haven't checked it yet, been raining every afternoon when I get home. Then I found, at times, it was hard to engage reverse.
Tried the pulling up the pedal trick, no clicks and situation wasn't better. I haven't crawled under the dash with a mirror to look at the adjuster for damage yet.
Any ideas??
Bad cable??
Bad adjuster assembly??
HELP!
Crai-zy horse
75
Fairfax
Jul 14, 2005
  • Jul 14, 2005
Trouble shifting into reverse is pretty common. It's just the syncros not lining up. Either move it into another gear and then try reverse again, or you can usually put it in nuetral and let out the clutch and then try again. As far as shifting into 5th goes, I haven't heard that one before. I'll look it up this evening in my Haynes manual if someone else doesn't help you out first. BTW, a Hayne's manual is an invaluable investment, so pick one up next time you go by an autoparts store.
I
Iggy50
  • Jul 15, 2005
I have one. The manual suggests depressing the clutch to within 1/4" of the floor then shifing from 1st to reverse. If there's difficulty then somethings wrong in the clutch system.
Last night I tried, while sitting still, depressing the clutch, counting to three, then putting it in reverse. No grinding. Did this several times with no trouble. I suppose the clutch is releasing peroperly since there's no noise.
Tried depressing the clutch, again while sitting still, then quickly shifting into 5th. Instant grind. Tried it with counting to three before engaging 5th, no noise.
I'm beginning to think it's a bad 5th gear synchro. And the warranty is expired.
T
texlex99
  • Jul 31, 2005
if you have an owners manual it tells you how to adjust
you put your foot under the clutch and pull up
then you push it down till it clicks
i dont think you have to look at it to check it
i am told mine is adjusted out completley and i need
a new clutch cable do you know anything about those
hope my info helps thanks
I
Iggy50
  • Aug 3, 2005
Looking at a service manual, swapping a clutch cable isn't very hard. About the hardest part is getting under the dash and playing with the self adjuster to remove/install the cable.
I did try pulling up on the pedal, no difference. No click either. I suppose the clutch cable isn't stretched, or worn, enough to need adjutment.
I've watched the ex drive and she practically rams it into fifth gear. I'm beginning to think she's screwd the trans up.
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
L
Engine 97 mustang gt manual weird idol when off the throttle and coasting in 3rd, 4th, or 5th
  • Lanezs
  • Jun 9, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
CLUTCH NIGHTMARES
  • 393LX
  • Dec 15, 2021
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 18, 2021
manicmechanic007
