Clutch ??
terr5178
27
The clutch grabs perfectly but while the pedal is out there is a little whine in the tranny. I believe it is the throw out bearing. So I loosened the clutch cable and found that the clutch whine turned into a rattle. The clutch TOB arm is vibrating. if i grab it it stops making noise. I adjusted the clutch so there is no slack in the clutch cable.noise is gone. Is the throw out bearing supposed to be spinning when the car is in neutral? Is it supposed to be disengaged from the pressure plate until the pedal is pressed in? How does that work? I was under the assumption that the throw out bearing only contacts the clutch when the pedal is pressed in. Am I wrong?
your throw out bearing is a 2 peice design. its made to have pressure against it while other parts move freely. might of been the cable was too loose which was causing the noise, if its gone now then you should be fine. usually when tob's start to go out they make a sqeaking/screeching noise constantly when the clutch isnt depressed.
