Cms stage 1 cams Installed
  • Thread starter Thread starter kuwait
  • Start date Start date Oct 11, 2008
First Prev 2 of 2
R
RoadconeTuning
458
Upstate, SC
Oct 13, 2008
#21
  • Oct 13, 2008
  • #21
im not familiar with that brand but most stage 1 cams will sound stock once tuned... you have to run a pretty big cam to get it to chop with a 2v.
kuwait
194
Oct 13, 2008
#22
  • Oct 13, 2008
  • #22
CobraRed_96_GT said:
idle rpm - it's a really simple adjustment. If i'm not mistaken i remember mine being 850 or 900. Stock is like 500/550 which leaves the cam constantly almost dying depending on how drastic the cam is.
My rev limiter is set to 6500 too I have a camera pic taken by my friend while data logging of it at 6450 - but dont know how to upload it to online from my phone.
mine is idling at 1k after install , the idle is working out after the car got to run around abit , a neat trick i learned turning the A/C ON drops the engine rpm by 100-150 which makes it less chobby , it almost sound stock really but the exhaust defiantly sounds louder.
wounder how if you get anything out of revving it up to 6450'ish
as for uploading from your phone , try using bluetooth to transfer the file over to your PC and then upload it to youtube
yea i figured as much , i pulled today at work and everyone noticed the idle and people were like... what did you do to the engine , should see the grin on my face , i am not realy hating the idle , i am getting used to it and loving it
scupking
1,186
Enfield, CT
Oct 13, 2008
#23
  • Oct 13, 2008
  • #23
Stage IIs will make the 2v have a nice chop.
CobraRed_96_GT
1,421
UCSD/La Jolla
Oct 13, 2008
#24
  • Oct 13, 2008
  • #24
most likely not - my peak is around 5900-6100 that i can tell from my last crappy dyno chart, but that's with ported heads. 6400 was just for datalogging so the tune would be spot on in case i ever did go that high again.
R
RoadconeTuning
458
Upstate, SC
Oct 13, 2008
#25
  • Oct 13, 2008
  • #25
and those stage 2's are huge as *****... 224/235 duration isnt it? thats a lot for a little motor that doesnt rev.
how high are most people turning stock headed motors those CMS/VT Stage 1 cams? i figured instead of shifting at 5600 id have to shift at 6k....
Stark77
501
Tallahassee, FL
Oct 13, 2008
#26
  • Oct 13, 2008
  • #26
I may pass up on the set of wheels and spring for Stage II's + Install if I can really get by with less than 300 for labor.
CobraRed_96_GT
1,421
UCSD/La Jolla
Oct 13, 2008
#27
  • Oct 13, 2008
  • #27
Don't expect it - that's stupid low for an install and a bit weird. Also, don't forget stage II's require the changing of springs.
mazen189
424
I.E. southern california
Oct 14, 2008
#28
  • Oct 14, 2008
  • #28
kuwait said:
yeah , i do , and the roaster is our neighbors , and he is a loud fella
Salamaat man, my mom is from Syria, and Dad's from Jordan. I actually plan on going their this upcoming summer, to syria that is..
glad im not the one around here
georgio440
195
Walnut Creek, CA
Oct 14, 2008
#29
  • Oct 14, 2008
  • #29
Man, I want a set of cams so bad... Sounds great!
Stark77
501
Tallahassee, FL
Oct 14, 2008
#30
  • Oct 14, 2008
  • #30
Yeah, 500 for cams, 200 for springs, 300 for labor would be a nice chunk of at least +20RWHP. That's an acceptable price for that type of gain.
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Oct 14, 2008
#31
  • Oct 14, 2008
  • #31
And if you do the labor yourself its even better. After this rear gets built im gonna start saving for a head/cam swap. If all goes the way i want it to that is.
kuwait
194
Oct 14, 2008
#32
  • Oct 14, 2008
  • #32
i find it rather expensive here , my brother owns a caprice ( 4-door Ls1 powered ) and the cam + spring install was $120 with pullies and thermostats was a 2 hours job , so i thought i was getting robbed when i payed that much money for my car
the car dynoed 361 rwhp and some smiliar torque with only boltons through an auto
vid of the thing running with awfull 3.02 gears in the rearend:
http://www.youtube.com/watch?v=IyVVK8szYA4
CobraRed_96_GT
1,421
UCSD/La Jolla
Oct 14, 2008
#33
  • Oct 14, 2008
  • #33
OHV cam install is way different - i'd do 2 of those before i'd do another one of mine, you dont even really need to "time/degree" since it's driven off the crank basically.
First Prev 2 of 2
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Sunday at 2:23 PM
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sunday at 2:40 PM
Bullitt347
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
