Cobra 70MM MAF on GT, any issues
The meter used on the GT & Cobra are the exact same meter :eek:
Neither are caled for 19's or 24's :nono:
Ford does not do that kinda thing with their OEM meters :Word:
Soooooooo
You can't just bolt on an OEM meter from a Cobra and a set of 24's
on your GT :)
Grady
when you say "tune" I am assuming you're referring to the ECU tune. So then, theoretically, I would need a cobra ECU to run 24# (or an aftermarket MAF or MAF piggyback)
and a cobra MAF isn't going to do squat other than be a paperweight.
Good stuff.
Grady is right - the fox A9*'s get 55 mm units. The fox cobra uses a 93 cobra specific MA meter (the transfer curve is different than A9's and SN's). Don't be fooled by one though (since it is a 70 mm unit as I recall).
