Cobra brake conversion proportioning valve
Sk8trfred
45
MA
This car was gutted and needs complete new brake lines I'm trying to do it the easiest and cleanest looking was I can. can the stock proportion valve be completely removed from the system and just run a T from the master to the front caliper and then run an adjustable valve to the rear?
  • Sponsors(?)
CarMichael Angelo
clearly, I’ve got something going on in that hole
SN Certified Technician
13,617
234
62
Birmingham, al
m.imdb.com
Potentially,....yes.
There is a wilwood prop valve/distribution block that works for both front and rear brakes. I'm using it on my car.
Reactions: Sk8trfred
Sk8trfred
45
MA
Yes.
Ditto on the wilwood peice. very nice looking part that I may incorporate in the future
Thanks so much, I was scratching my head with this one and this piece makes my install even easier than the way I was figureing it in my head.
Thread starter Similar threads Forum Replies Date
ZeroFoxGiven 9in rear end w/disc brakes [Parking Brake] 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
ZeroFoxGiven Fox Please help identify these brake calipers 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
1200gt Brakes Low Brake Fluid Sensor Connection 86gt With 93 Cobra Master Cylinder 5 Lug Conversion Fox 5.0 Mustang Tech 26
Jamesrolls5point0 Brakes Fitting A 93 Cobra Booster Fox 5.0 Mustang Tech 4
droptopfox Expired Foxbody/ Sn95 Cobra Brake Conversion Parts-las Vegas Wheels Tires Brakes 0
J Expired Fs: Mustang M-2300-k 5lug Cobra Disc Brake Conversion: Suspension Parts 4
B 5-lug, 8.8 And Cobra Brake Conversion 2.3L (N/A & Turbo) Tech 8
StangYellow Gt To Cobra Brake Conversion... From Scratch SN95 4.6L Mustang Tech 6
lanky83 COMPLETE 5-Lug Conversion, New 13" Cobra brakes, Rearend w/ Auburn PRO diff Wheels Tires Brakes 2
T Question: '87-'93 to '94-'04 Cobra front brake conversion Fox 5.0 Mustang Tech 3
B Mach 1 / Cobra Brake Conversion Kit - Raleigh, NC Wheels Tires Brakes 4
T Cobra brake conversion problem (new one to me...) Classic Mustang Specific Tech 0
killer5.0 5 lug conversion/cobra brakes...what fluids do i need and how much (brake, gear) Fox 5.0 Mustang Tech 0
393strokervert what size wheel needed to clear 03 Cobra front brake conversion? 17"? 1994 - 1995 Specific Tech 6
ironhead498 cobra brake conversion Fox 5.0 Mustang Tech 11
12sec67 who has the cobra disc brake conversion? Classic Mustang Specific Tech 6
Pokageek Cobra brake conversion..Correct "banjo" bolt? 1994 - 1995 Specific Tech 8
streetstang03 wheres the best place to buy Cobra brake conversion kits? 1996 - 2004 SN95 Mustang -General/Talk- 13
4MuscleMachines So who else makes brackets for the Cobra brake conversion? Classic Mustang Specific Tech 2
Fox_84 02 GT to Cobra brake conversion... Fox 5.0 Mustang Tech 3
E Specific website for cobra brake conversion kit... 1996 - 2004 SN95 Mustang -General/Talk- 5
CochinoFilipino Cobra Disc Brake conversion kit on an 86? Fox 5.0 Mustang Tech 2
MineralG2k2GT Rear Cobra/Bullit Brake Conversion Kit Question SN95 4.6L Mustang Tech 5
95GTV8 Cobra Brake Conversion 1994 - 1995 Specific Tech 6
6 Currie rear Cobra brake conversion brackets for 9 inch Classic Mustang Specific Tech 3
6 Drum Hubs & Spindles for Cobra Brake Conversion Classic Mustang Specific Tech 0
9 Cobra Brakes (Sn95) Conversion Brake Lines Fox 5.0 Mustang Tech 11
GToddyT5 GT to Cobra rear brake conversion SN95 4.6L Mustang Tech 12
GToddyT5 Cobra Brake Conversion SN95 4.6L Mustang Tech 7
M 5 lug/cobra brake conversion Fox 5.0 Mustang Tech 2
D The definitive SN95 GT to Cobra brake upgrade. Part numbers and pictures. 1996 - 2004 SN95 Mustang -General/Talk- 1
nickyb Brakes O.k. Two weeks ago i started cobra brake swap on my 93 lx. Fox 5.0 Mustang Tech 14
H cobra brakes Fox 5.0 Mustang Tech 2
C Question on 'Cobra' rear disk brake calipers 1996 - 2004 SN95 Mustang -General/Talk- 1
Cool Beans Will my Power Booster Operate Cobra Brakes? 1965 - 1973 Classic Mustangs -General/Talk- 1
J Rear brake kit SVT Tech Forum 3
S SN95 Cobra Brake swap hard lines 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
ebowie SN95 SN95 GT to Cobra brake swap... in need of rear caliper mounting brackets and anti-moan brackets 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
S Difference between 03 Cobra and GT brake lines? SN95 4.6L Mustang Tech 0
ebowie 1995 mustang gt brake upgrade to cobra brakes 1994 - 1995 Specific Tech 5
Mstng93SSP For Sale Cobra front brake calipers for 5 lug swapped fox Wheels Tires Brakes 0
Mstng93SSP SOLD 2003 cobra front brake calipers, brackets, and lines. SOLD Wheels Tires Brakes 2
9 Learn How To : Custom dual piston big brake install . (modification required) 1996 - 2004 SN95 Mustang -General/Talk- 0
nickyb Cobra brakes frt an bk can i do half at a time? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
A if you're Cobra, Bullitt, Mach 1 front brakes rattle.... 1996 - 2004 SN95 Mustang -General/Talk- 0
M Low Dust Semi Metallic Brake Pass? 1996 - 2004 SN95 Mustang -General/Talk- 2
M Help Removing 1996 Cobra Master Cylinder 1996 - 2004 SN95 Mustang -General/Talk- 1
Mstng93SSP What color should I paint my cobra brake calipers on my foxbody 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
S Brakes 1994 cobra's brakes seize while driving a few miles? (Pedal swap) 1994 - 1995 Specific Tech 2
Stroked88 Cobra Brake Booster Source 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 45
