What are you guys using for brake lines. I am looking to see if I need adapters or if the Later Cobra stuff will fit. I will be using stainless braided lines as this car will see road course time.
Thanks
J
Thanks
J
in terms of the rear, all I did was use the existing lines on the sn95 cobra rear, but I put a union where the brakeline used to go in (to make it straight line there), and I tapped into the line in the stock rear location and thats where I put the "T" that controls the rear brakes. Havent had a problem yet.91RRLX said:Thanks guys, What about the rear hard lines to the soft lines going to the calipers, will 93 Cobra lines work, or do I need adapters?
Car RamRod said:in terms of the rear, all I did was use the existing lines on the sn95 cobra rear, but I put a union where the brakeline used to go in (to make it straight line there), and I tapped into the line in the stock rear location and thats where I put the "T" that controls the rear brakes. Havent had a problem yet.
which lines are you speaking of when you say existing lines on the sn95 cobra rear? the hard line or flex line at the caliper?
I meant the hard lines that are on the rear. I would have used the ones off my stock rear, but they were crushed. My solution seemed much easier.91RRLX said:which lines are you speaking of when you say existing lines on the sn95 cobra rear? the hard line or flex line at the caliper?
