Cobra bumper not Cobra R
dbrufus1234
92
Where can you find a cobra front bumper on the internet, beside fordpart.com, every place i can find only has cobra R front bumper and i like the cobra bumper alot more than the cobra R
The gears usually aren't that expensive, not more than $200. It's the install that can be pricey. You've really gotta watch where you get em done. I've heard a lot of complaints from people about bad gear installs.
And on ratio, it depends on your plans for the car. If you plan on using a FI at some point 3.73s are pretty accepted, if you plan to stay NA 4.10s are where it's at and if you have an auto then bump those up one, 4.10 and 4.30 respectively.
It's mostly gas mileage. The reason most people say to go with a lower ratio if you have FI is so you can keep some traction. Although if you were using a centrifugal blower then you want to get into the higher RPM faster so having more gear could be handy.
i called ford today to see how much it would be to paint a bumper cover and hood and they said it would be around $500, that seems kinda pricey to me but i dont know? is that too expensive for paint?
