cobra computer
  • Thread starter Thread starter gtpitstop
  • Start date Start date Jan 19, 2006
G
gtpitstop
  • Jan 19, 2006
we modified a 95 cobra with gt 40 heads, bbk headers, cold air-intake, 75mm throttle body, ford racing 30lb red top injectors, granitelli maf and are having problems with it idleing. it sounds perfect once over 1000 rpm but will cut out as soon as we let it idle. also the car does a self-diagnostic every time we turn the key on where the fans will self test at high and low. when the fan kicks in with the vehicle on, the idle jumps to 1900 rpm on its own and spits a 0543, 0542 codes for the fuel pump. is it possible that the computer just needs to be re-programmed or is it something else?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jan 19, 2006
  • Jan 19, 2006
with no more mods than that , put the stock injectors , stock MAF back on , and then see what it does ....
legalize420
1,541
South Florida
Jan 19, 2006
  • Jan 19, 2006
30's are too much. i was running rich with 24's
D
Daggar
3,902
  • Jan 19, 2006
Keep in mind that STOCK injectors for a Cobra computer are 24 lbers. Not 19s. The Granatelli meter should be calibrated for 19s though. IN other words: With a Cobra computer, you should have a meter calibrated Ford stock along with 24 lb injectors.
QDRHRSE
1,590
Palmdale, CA
Jan 19, 2006
  • Jan 19, 2006
I was sort of thinking the same thing. What is the calibration on the Granatelli meter?
G
gtpitstop
  • Jan 20, 2006
ford racing told me that 24lbs injectors are good up to about 375 hp, any more would require 30lbs.
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Jan 20, 2006
  • Jan 20, 2006
30s are to much.. numbers cant beat the actual experience of needing smaller injectors.. and im with daggar 100%.. go with 24s and make sure the MAF snesor is calibrated for 19s
D
Daggar
3,902
  • Jan 20, 2006
Or ditch the Cobra computer and grab up an A9L or A9P. When a meter is calibrated for specific sized injector (sight unseen for a Fox), they're calibrated based on the fuel tables in these computers.
HISSIN50
34
129
Jan 20, 2006
  • Jan 20, 2006
The cobra computer for 94-95's is much better than the 94-95 GT computer (a reason why Gt people run the J file). And going down to an A9 series is a large step down IMHO. Add in needing fan a controller, etc and it is not a wise move.
I would be tracing the code running situation down first and then take it from there. Is the meter/puter combo calibrated for the 30's?
Good luck.
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
T
SOLD 1979 Ford Mustang Cobra Hatchback 302 C4 Modified
  • toasterboy1
  • Nov 15, 2024
2K
Fox Body Mustangs For Sale (1979-93) Dec 20, 2025
toasterboy1
T
Car idles good, then VERY SUDDENLY dies
  • Vulpes5.0
  • Jan 17, 2024
5K
Fox 5.0 Mustang Tech Feb 4, 2024
Vulpes5.0
F
1993 Cobra flooding
  • FireFoxCobra_SVT93
  • May 20, 2022
6K
Fox 5.0 Mustang Tech Mar 11, 2023
nickyb
