cobra crank Bennifits in a Gt engine?:shrug:
Tyler Munster
41
Boston MA
Ok so i got my 96 gt dynod and im pushing 169 rwhp and 210 trq complettly stock how i bought it no tune up . im going to pull the engine and rebuild it thanks to some advice i got Here before. my new question is i read in an old MMFS mag i could throw a forged cobra crank in My questions is what are the benefits of this.i figured if i am building the top build the bottom too right . heres my list of mods to the car at the same time i rebuild . this is my daily driver for 5 months out of the year i am not looking for a weekend warrior just want to tear it up a little and not be pushing the lowest hp in my auto club Mind you its a firebird based club and im the only one with a Stang so pleas help . what would the Gustament be on this engine set up
thanks
Tunable induction CAI ( tho one that pulls from outside the fender wall)
C&L plenum( have)
80 C&L maf(have)
75 Mm throttle body mybe bored Any suggestions
Pi intake (have)
Pi Heads (have)
Comp cam XE262AH
comp cam Springs
24Lb FRPP injectors(have)
timing Gears and chain ( any suggestions trick flow or cloys comp or steeda ect)
March perfamnce pullys
BBk Shorty headers(have) ( O/R x pipe Slp Loud mouth 2 Catback)
slp 180 degree T stat (have)
MSd or weapon x coils havent decided any one have experince with weaponX
FRPP Wires
SCT elimantor chip
If the cast crank is in good shape you'd see no benefits to going forged with that combination. In addition, if you did go to the Cobra crank, you'd have to source a new 8-bolt flywheel/flexplate too.
For the timing components -- arms, guides, chains, sprockets etc, I'd just stay OEM.
A 75mm TB is more than enough for that combo.
I wouldn't have bothered with the shorty headers though you might as well use them since you have them.
I wouldn't bother with the pulleys. They don't give much power for the cost. If you must have them, go Steeda.
If you're not experiencing any misfires, I wouldn't bother with the coils and I'd replace the wires only if they're needed it (i.e. age cracks, corona discharge, misfiring when wet etc...)
trinity's got some great info...doing a lot of research for the timing set up on my car, i was able to disover that the stock timing components are more than capable...no need to upgrade
with the pi intake, heads, and cams alone you are going to see a fairly decent result in power.
the stock crank in 99-04 mustangs can handle a pretty good amount of power, not sure about the 96-98's but they should be atleast some what similar..no need to cobrasize your crank!
If the OP thinks that supercharging or serious nitrous is a possible future upgrade he might think about going forged on all reciprocating components -- crank, rods and pistons -- while he's got it apart but if it's going to be a n/a daily with a factory rev-limit, cast would be fine.
