Cobra engine from a 96 explorer?
  • Thread starter Thread starter StreetDreamsGT
  • Start date Start date Jun 16, 2006
StreetDreamsGT
449
New Jersey
Jun 16, 2006
  • Jun 16, 2006
I bought a 96 explorer engine to convert to an H.O.. I thought all explorer engines were flat tappet cams, and you had to use the lifters, and spyder from an H.O. engine, but when I pulled off the intake I looked down in the lifter valley and it was already using a hydraulic roller cam. This engine is all original, has the GT40 Irons, and intake (explorer version), and I bought it from a junkyard complete with engine wiring harness, and sensors, so unless the original owner of the engine converted it, this is how it came from the factory. Anyone care to shed some light here?
JChalfan
551
Bellevue, WA
Jun 16, 2006
  • Jun 16, 2006
I thought all the explorer 5.0's were roller motors.
I think truck 5.0's (and lightning 5.8's) were flat tappet motors?
Jeff
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 16, 2006
  • Jun 16, 2006
Check to verify that it is indeed an HO engine. Remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Jun 16, 2006
  • Jun 16, 2006
Explorers and Mountaineers were all roller's
StreetDreamsGT
449
New Jersey
Jun 16, 2006
  • Jun 16, 2006
Thanks Jrichker, the only problem is it's sitting on an engine stand stripped down to the long block, lol. It's ok though, i'm not planning on using the cam in it anyway, i'm going aftermarket. Am I able to use the explorer roller rockers, pushrods, balancer, etc even if it isn't an H.O.? I've already got an aftermarket tb, and intake manifold that will be going on in place of the explorer pieces, so I don't need to worry about modding the tb or anything, I'm only using this engine for the block and the heads.
StreetDreamsGT
449
New Jersey
Jun 17, 2006
  • Jun 17, 2006
Anyone?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jun 17, 2006
  • Jun 17, 2006
explorers didn't come with roller rockers , only the cobras did , the balancer, timing cover and all will need to be changed along with the oil pan , oil filter mounting attachment , and oil sending unit
StreetDreamsGT
449
New Jersey
Jun 18, 2006
  • Jun 18, 2006
Ok so now i'm definitely confused, because the rockers on this engine look just like the ones on my 86 block.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
H
1995 cobra engine noise help
  • Holt2010
  • Nov 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 8, 2026
Holt2010
H
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
