Like the title says......
I'm still piecing together my cobra/5 lug swap parts and was wondering how viable it would be to install the fronts and swap the rear drums out later since I already have all the front components. I would imagine this would provide vast improvement over stock fox brakes because most of the braking is done with the fronts anyway.
If I did this, the set up would be as follows:
94 Spindles
94 GT M/C & Booster
M.M. adj. Prop Valve
M.M. Brake Prop Valve Eliminator kit, 1987-93
M.M. 94 GT M/C adapter
M.M. front braided lines
Front Cobra 10 anniversary calipers
Cobra front 13" Rotors
Stock Rear 5 lug Drums
5 lug fox length axles
Would I need any other parts? Would there be any issues using the rear drums with the newer 94 booster and M/C?
This would be a good option for me for the time being b/c I would save some $$$ on holding off on purchasing the rest of the stuff I need for the rears. Plus I could run 15" rims on the rear for trips to the track and I wont have to touch the E-Brake for the time being either.
What do you guys think???
94 Spindles
94 GT M/C & Booster
