You can do it.
Unsure as to which MC to use, but go about the prop valve as if you were installing rear disk brakes.
Use the Ford Racing part ot "gut" the factory internals of the stock prop valve and install an asjustable valve at the brass union on the pass side firewall.
This will allow you to dial in a little more rear brake pressure if, for example, you have wider stickier tires offering more grip.
Honestly it's something i would do on a stock Fox system period. The way the brakes lines are plumbed is retarded. The driver's side front brake sees direct pressure off the MC and the other side is proportioned with the rear. I guess ford's reasoning is if you lock the left side front up, the car will pull to the right...away from oncoming traffic.
But a new MC with a 3-2 conversion and adjustable prop valve is the way to go
