Cobra Intake Manifold Installation
95GTV8
386
Washington State
how hard of a job is this? i have plenty of time to do it, and my dad has a garage with tools etc, he has decent car knowledge, but he doens't know much about newer engines most of his knowledge pertains to the older cars he works on, im wondering how hard of a job is this i'd really like to save the $ that i'd have to pay a shop to install this, im also wondering if anybody could direct me to a detailed tutorial with pictures (hopefully) of how to do this, information of any kind about this will be greatly valued and i will be very thankful.
go for it. not hard at all. a little time consuming the first time, but its worth it. get new bolts.
pcv grommet and screen? and how hard is it to put those on aswell as a new thermometer? also what bolts do i need? is their any place i can order the bolts online? and if so do any of you guys know the exact bolts i'd need?
piece of cake. just drop the screen in there then put the grommet in the hole then the valve follows. thermostat housing is only 2 bolts. i got my bolts on ebay. do a search for mustang intake bolts.
http://www.allfordmustangs.com/Detailed/614.shtml
That post helped me out alot.
you will need a gasket set (felpro ms95952 will work) you can reuse 4 of the 6 bolts for the stock upper, you will need two 6.5" long bolts (grade 5 or 8)for the longer center ones though. You will also need a thermostat, and thermostat gasket. I replaced my pcv valve, pcv valve grommit and pcv valve screen (got from dealership).
anyquestions ill be happy to answer them.
