cobra intake manifold
What does Stage 2 mean? To me a ported intake is a ported intake.... regardless of that, A cobra intake will flow very well if the bottom is opened up. You should check you www.tmossporting.com for some information. You can also look up TMOSS's I.D. to see what his car puts down with a ported cobra.
In your case, you will really need to swap heads to see a huge gain. I'd start saving for the H/C(?)/I and do everything all at once.
Stage 2? What is that? Got a flow number?
At any rate, on stock heads (non listed) porting a Cobra style intake is a waste of time and money.
Edit:
Let me tell you what I think Stage 2 is - it means the porter sits at a bench without considering the combination of parts the intake might be used on and just cranks out one after the other the VERY same way. I don't do "Stages" and I never will.
tmoss said:
don't like my answer huh?
I guess not... But let's spell out the 3 biggest restrictions on a Stock 5.0L motor just to be clear. (Listed in order of bigest to smallest)
1. Heads
2. Lower Intake
3. Air tract [MAF, TB] and the stock mufflers.
Correct my flow numbers so I get this right. A stock headed Mustang with no port or polish work will only flow 170CFM MAX. Said ported cobra intake will flow 230+CFM.
If you put any big intake on that engine those flow numbers will kill the velocity of the air entering the combustion chambers (port velocity => see www.thumperoforangepark.com for a good summary) The lost velocity will translate into a sluggish running motor off the line and on the street. Sure the motor will scream above 3,500 RPM's, but with a pair of heads that are done breathing at 5,500 you are only alowing yourself 2,000RPM's of power band.... It would be like driving around in a Turbine powered car. Not a good idea, but it's your money and your car. Now if you were to take that $400.00 - $500.00 [I'm guessing here] and put it towards a set of heads from Edelbrock, AFR, Trick Flow, etc you would be much better off and more happy with your car.
If you don't have a lot of money for a set of aftermarket heads (who does?) you can try looking for a V-8 explorer with iron GT-40's on it.
Remember Bigger is not always better.
crane cams what? roller rockers? camshaft? it doesn't say in ur sig what crane cams item, and theres only one camshaft, so i didn't think it was cam"s" lol you need heads - i have AL heads and a non ported cobra intake, and it runs very well -
Your answer doesn't make him feel faster...just having the "stage 2" port job will mentally increase the performance by 20%. This can also be seen when people exclaim how much better their car runs after an oil change. I wonder how much better my heads would flow with a "stage 2" port job...guess I only got a stage one.... :(
Stock upper all by itself - mid 190cfms
Stock Upper + stock lower - mid 130cfm
Stock E7 head intake runner - ~160cfm
Where is the largest restriction there?
a 60mm is up to the task of flowing that air, so a 65mm is more than up to the task.
Exhaust system is always a good move on a Mustang, but the stock shorties are better than most give them credit for.
I was refering to the stock heads with an aftermaket intake.
Or a set of heads with a stock intake on it. I should have worded it better..
Please explain this to me. When porting something, do you port it to max most of the time? I uderstand that you wan't to match the components, but possibly like the original poster, I see these ads for a Stage 1 port job, Stage 2 port job, and Stage 3 port job. What's the deal? How else do you classify it?
I mean, let's say a guy wants his intake ported. He gives you the specs of his setup. And then when he get's it back, he was hoping to get it ported more than it was. Then what? I guess I'm confused.
When you ask a porter to do your intake you have to trust he knows what to do with the intake for your combination of parts. I port to the head to be used on a car, if it's a ported head, then I have a template made from the head for me to use (instructions on how to make a template are on my website). I do not often exactly match the head runner size - I stay just shigh of it to allow some adjustment room for the intake on the heads. Having the intake runner just smaller than the head is not detrimental to flow for most applications - most of the gain from porting occurs due to what is done a little further up in the runner anyway (and that's why a pure "gasket match" leaves flow on the table).
This "StageX" stuff is just a marketing tool.
Thanks for the clarification TMOSS. My previous post was in no way a slam to you or your porting brotheren. I am more than happy with the lower you ported for me.
After hearing what you had to say, I see that these ads are just BS. How could any "off the shelf" port job be precise for any certain application anyway?
