Cobra intake swap question....
  • Thread starter Thread starter BYRDPE
  • Start date Start date Sep 4, 2007
1 of 2 Next Last
BYRDPE
1,556
Memphis,Tn.
Sep 4, 2007
  • Sep 4, 2007
What do I do with the two hoses that were connected to the EGR spacer on my stocker?
One is coming from the black water pipe that's bolted to the lower and the other hose is coming from a fitting on the lower on the rear driver's side. Do both of these need to be blocked off?
I know the Cobra has a built-in EGR.
Why does the EGR on the stock intake have water running through the spacer and the Cobra doesn't?
88mouse
630
Mooresville nc
Sep 4, 2007
  • Sep 4, 2007
You can either hook them together or plug them off.
BYRDPE
1,556
Memphis,Tn.
Sep 4, 2007
  • Sep 4, 2007
Cool....
Thanks
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Sep 4, 2007
  • Sep 4, 2007
I bought a plug for the rear port in the lower manifold and used a short piece of hose with a bolt plugging it for the port on the coolant tube.
BYRDPE
1,556
Memphis,Tn.
Sep 4, 2007
  • Sep 4, 2007
Where did you find the plug?
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Sep 4, 2007
  • Sep 4, 2007
I just unscrewed the nipple and took it up the street to my local parts store. They had a brass plug that matched the threads. Cost me ninety cents.
BT73000
  • Sep 5, 2007
Ford uses the engine coolant to help cool the egr spacer and gases before they enter the engine. Thats why the the lines are hook to it. I feel like the Ford engineers are alittle smarter than me and designed the egr system like they did for a reason so thats why I wouldn't plug them off.
Flavadave4
1,044
21
49
Utica, NY
Sep 5, 2007
  • Sep 5, 2007
....that and the fact that the EGR has no negitive effect on performance at WOT should be enough to leave it hooked up as factory setting.
ninety15.0
1,336
  • Sep 5, 2007
Thats funny you guys say that because those same ford engineers...probably the better ones designed the cobra...and the cobra doesnt run coolant through the EGR area does it? I wonder why.
The coolant through the EGR spacer is pointless...plug em
Flavadave4
1,044
21
49
Utica, NY
Sep 5, 2007
#10
  • Sep 5, 2007
  • #10
You know, thats a great point and I never thought of it like that
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 5, 2007
#11
  • Sep 5, 2007
  • #11
Ford engineers also zip tied a peice of plastic conduet around the gas filler neck on all 96-04 Mustangs. Well, this keeps condensation and dirt/mud in there which causes them to rot out!!!!!!!! I need one for my mod swap and every used one I look at in my place of business, is rotted out!!! I finally found an 04 with 4,000 miles and that one was a little rusty, so I sanded it and painted it. Ford engineers aren't always the brightest!!!!!!!!
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Sep 5, 2007
#12
  • Sep 5, 2007
  • #12
Well, since he's installing a Cobra intake and the Cobra intake (which was designed by Ford engineers) doesn't have the facilities for EGR cooling, if he doesn't cap off the lines, he's going to have coolant shooting everywhere when he starts his car.
I'd highly recommend that you actually read and comprehend the entire post before offering your opinions.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Sep 5, 2007
#13
  • Sep 5, 2007
  • #13
That's the million dollar question.
As long as i've been into Mustangs (10 years) there have been heated debates on it's purpose and if it's necessary
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Sep 5, 2007
#14
  • Sep 5, 2007
  • #14
My theory on the EGR coolant lines is that their primary function is cooling of the EGR. The EGR gases get pretty damn hot (400-500 degrees) and the coolant is a relatively cool 200 degrees.
Now, NOBODY drives aroung at WOT forcing the EGR to stay closed. Most often you are just cruising through the gears which means the EGR is pumping inert gas into your engine helping your fuel economy by leaning out your mixture a little. Over time, the heat soak from this gas will envelop the entire TB area. These mystical coolant lines help take some of this heat away. Even though the EGR is off at WOT, you still have residual heat from when it was pumping away.
It's the same deal as A/C. Everyone knows when the a/c is off, there is no HP draw on the pulley. However, idle your car with the a/c cranking and heat builds up robbing power even if you turn it off.
Some guys claim it's for icing. I have no idea and have never heard of anyone icing a 5.0 intake up. With a little testing, we can see what conditions this would happen under and if the lines do help....however none of you guys are gonna pay me to do this, so it will never be done
WHy doesn't the Cobra intake have them?? I think the neck was slightly redesigned pushing the EGR away from the intake slightly. There is also some cooling fins and the metal in the area is thinner in general allowing it to heat and cool more quickly.
What would I do?? If you have a stock intake with a stock functioning EGR (and aren't one of those that disconnect it without tuning the fuel curves in the computer) then you should leave the lines alone.
If you've correctly deleted the EGR, then i would remove the lines
If you have a Cobra Intake, you don't have a choice but to remove them or maybe plumb them into the passenger cabin and make a heated cup holder to keep your coffee warm in the winter??
Like i said before, i have yet to see a solid answer from a Ford Engineer on the lines. I myself am an engineer, and the above is my best guess but don't hold it to me.
cenok is family
1,409
69
79
Norman, Ok
Sep 5, 2007
#15
  • Sep 5, 2007
  • #15
all wrong!
mustangs don't have cupholders, you know that! lol
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Sep 5, 2007
#16
  • Sep 5, 2007
  • #16
cenok is family said:
all wrong!
Doh!!! I'm so used to driving an Sn95 around that i forgot Foxes gotta use the e-brake and seat!!!
Flavadave4
1,044
21
49
Utica, NY
Sep 5, 2007
#17
  • Sep 5, 2007
  • #17
.......heated seats and steering wheel/ shift knob grip FTMFW
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Sep 5, 2007
#18
  • Sep 5, 2007
  • #18
Oh i can just see the post
"So i was doing 65MPH on the highway when the coolant lines i have feeding my custom steering wheel warmer, seat warmers and coffee mug warmers all ruptured in the cabin spraying boiling hot coolant on me and my girlfriend...."
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Sep 5, 2007
#19
  • Sep 5, 2007
  • #19
The Ford Service Manual says they are there for Cooling purposes, the late model GM Engines do just the opposite and provide heat to prevent icing in the Throttle Body.
408gt91
114
N.H.
Sep 6, 2007
#20
  • Sep 6, 2007
  • #20
i ran that cobra intake with the lines blocked for 2 years with no problems.no worries you'll be fine.
1 of 2 Next Last
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Saying Hi
  • BriansNSane
  • Dec 20, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 21, 2025
BriansNSane
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
Intake vacuum lines
  • cnorman31
  • Mar 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2025
Scrapla347
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
