Cobra Intake VS Explorer Intake??
The lower intakes are the same. The GT40 also shares the same lower. I belive a few years explorer had an external EGR so no EGR passage. The uppers flow much the same. They are pretty much identical.
gooch06 said:
What's the difference between a 1993 Cobra Intake compared to the Intakes from the 1996-1998 Explorers???
Basically looks, except that the '93 cobra intake had a built in EGR spacer while the Explorer setup uses an EGR spacer I believe. And for the SN owners out there, an SN95 adapter elbow will work plug and play with the explorer intake while it needs some fabrication on a 93 unless you do a Fox TB swap.
