cobra intake
I went to a local hardware store with the intake in hand and found the longer ones I needed(don't remember what size/get at least a stage 5 or stronger bolt). You only need to replace the top 4 bolts the lower ones on the upper intake are fine. Your egr hole is located on the intake elbow, look at the passenge side header and follow the pipe the leads to the intake thats the egr.
Burnouts said:
is the cobra intake capable of 400 hp and isn't a 94-94 better for a 94-95
it is, not NA...but it would be difficult(damn near impossible) to see 400 wheel horsepower NA out of a 302 anyways....a 94-95 intake isnt really any better for a 94-95 car since all aftermarket intakes are really made for the 93 and under cars
Burnouts said:
if and when i find a cobra intake what all will i have to replace to make it work
For a Cobra to make 400RWHP naturally aspirated and at less than 6,000 rpm, it's gonna take a lot of work. 400FWHP is more in reach with porting the lower, but that won't be a cake walk either.
the a Cobra intake, F-cam, and good heads i would expect to see 285-290rwhp....there are better choices out there in the power department than the Cobra intake, and F-cam.....
....1/4 times are hard to guess...Paul(Killercanary) runs 12.3's in his very with 293rwhp but he is an AMAZING driver.....400rwhp should be good for 11's easy if you can drive....but its going to be an amazing feat as tmoss said to see that NA on a 302....even flywheel hp 400 is iffy, because thats like 340rwhp....and the most power ive seen put down recently is GTJake with around 325rwhp(i know thats close to his number) and he is rockin AFR's a ported Edelbrock manifold, and an FTI cam and his intake and cam are better than an Fcam, and a Cobra intake....
Anthony
Anthony
i'm not set on the cobra intake i will do more if i need to and i might not even stay witht the 302 i deliever auto parts and in the back of our building is a really good machine shop and i get good deals on machine work so a 331 isn't outta the question and better heads intake cam also. a 331 should be able to get 400 rwhp right?
