Alright, I'd like to get my car out pretty soon, but it needs a repair. I put in new temperature sensors last year, and immediately after I did that it started leaking coolant around the front of the intake, like around the distributor (small amount where the intake meets block) and it's collecting at the top of the timing cover or whatever. Not a horrible leak (was still driveable) but a leak nonetheless. A couple of people surmised that I overtightened the temperature sensor and might have slightly cracked the bottom of the lower intake or something. This is the only thing I think it could be, because I replaced the timing cover/water pump gaskets, and replaced the intake to head gaskets again just to be sure it wasn't a bad gasket (even though they had less than 1000mi on them), and the problem persists.
So, my question is, would this be repairable? Like if I take it to a machine shop or something? Otherwise, this is a Cobra intake, so I would imagine getting a used lower off of an Explorer would work as well. I have called around and apparently there are a couple of different codes for the Explorer, and I am not sure which one works. Car-part.com comes up with these different IDs:
F67E-BB
F87E-CA
XL2E-AB
Anyways, maybe the simplest thing would be to get the current lower repaired if that is even possible. I know another option would be to buy a whole new intake (like an Edelbrock) but I had my car dyno tuned with the stuff on it now, not sure if throwing a different kind of intake on my car would screw everything up now or not.
Any input would be appreciated!
F67E-BB
F87E-CA
XL2E-AB
