  • SN95 4.6L Mustang Tech
cobra problems
  • Thread starter Thread starter TRPLBLAKSVT
  • Start date Start date Apr 23, 2009
T
TRPLBLAKSVT
Arizona
Apr 23, 2009
  • Apr 23, 2009
Whats goin on fellas? I have a 97 cobra vert with all the major bolt-ons and ive been havin some probs. Ill fire the car up n it'll run just fine until it gets up to temp then itll start runnin like ****. It will start missin and just run rough, if I kill the car and let it cool for a few ill try and fire it up, it will fire and immediatly start missin and die even gining it gas, almost seems like its loosin fuel pressure along with somethin in the ignition, the problems almost exclusivly happin when the car is up to temp, but its not overheating.. can anyone one help??
04gtdrop
532
Sac, CA
Apr 23, 2009
  • Apr 23, 2009
Is your CEL on?
Have you done any work to it at all, or did this just start happening all of a sudden??
T
TRPLBLAKSVT
Arizona
Apr 23, 2009
  • Apr 23, 2009
it pretty much just happind all of the sudden, buts its been kind of an on going thing the past two months, tryin to figure **** out. its throwing a lean code for both banks
NO BRAKES
129
Avon Lake, Ohio
Apr 23, 2009
  • Apr 23, 2009
put a fuel pressure gauge on it. maybe the FPR is not functioning properly. or ive had the issue before that i thought it was the fpr, but ended up being the pump.
LaserSVT
3,548
233
Apr 23, 2009
  • Apr 23, 2009
Dude, how many places did you post this? I have counted 4 so far
See my response in one of the other same titled threads
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
D
95 cobra (stock) Fuel pump or Distributor?
  • drop5ohhh
  • Jul 23, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 1, 2025
gkomo
Resolved 98 cobra,crank no start
  • Bigred98
  • Jun 23, 2024
SN95 4.6L Mustang Tech Jun 29, 2024
Bigred98
TTSaleen's Foxbody Project
  • TTSaleen
  • Apr 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
TTSaleen
