cobra rear brake problems
I recently ordered a set of cobra rear calipers and rotors. when i tried to install them i found that the claiper didnt reach my stock GT backing plates. so i found a kit from ford racing ( PN M-2300) this kit came with cobra backing plates. i installed these and reinstalled the cobra rotors and calipers. every thing fit great. but when i test drove the car the RR rotor moved out and rubbed against the caliper bracket. its only when i make a hard left corner. i check to make sure the axle isnt falling out and its not......good right? any other ideas?
Has to be axle related... maybe the axle itself is flexing or more than likely the axle bearings are shot...
The reason I say this is that in theory the position of the axle (tire wheel etc) and the brakes are fixed since there is no relative motion designed in around them. With that being said you have relative motion so something has to be flexing or moving around under these hard loadings.
