  • SN95 4.6L Mustang Tech
Cobra short block compression
  • Thread starter Thread starter spederman
  • Start date Start date Oct 9, 2008
spederman
732
  • Oct 9, 2008
Ive been thinking about a forged short block a lot lately. I can probably get a 03/04 Cobra short block for less than $2K. Then i want to upgrade my S trim to a T trim and push a lot of boost to get into the 600HP range. Does anybody know, with the cobra short block, would the compression ratio be too high to push maybe 20psi? Would i be better off getting a different short block?
Smokeurhonda
457
Maryland
Oct 10, 2008
  • Oct 10, 2008
03-04 cobras have 8.5:1 compression. I'm not sure if the 2v heads would change that or not. I'm sure someone on here knows. If you maintain the 8.5:1 you can throw 20#s at it with no problems.
Green&GoldGT
302
Virginia
Oct 10, 2008
  • Oct 10, 2008
With PI 2v heads you're going to see about a 10:1 compression ratio, which is really kind of high for any level of boost. Your going to have to pull out alot of timing, which is bad, and run high octance to prevent detonation. With a centrifugal blower, you will need around a mid 9:1 compression ratio, or maybe lower with that much boost.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 10, 2008
  • Oct 10, 2008
compression will be too high , just get a piston and rod kit for your current engine , probably run you a little over a grand
Z
Zoie_daGT
58
  • Oct 11, 2008
The stock Terminators have an 8.5:1 compressiong but, that is w/ the 2v heads. I would think that will raise since the 2vs have a 9.5ish:1 compression.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Help with Engine Build
  • 93gtmustang
  • Nov 13, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2024
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
