  • 1994 - 1995 Specific Tech
code 124
  • Thread starter Thread starter 94kbvert
  • Start date Start date May 27, 2008
9
94kbvert
  • May 27, 2008
94 mustang gt with a Pms series 4 83lbs injectors with pms driver mass air meter
Pro m 92mm . Replace Tps senor set .988 at idle mass air voltage .76 at idle. any help is welcom. thanks in advance
HISSIN50
34
129
May 28, 2008
  • May 28, 2008
If you can datalog, see if your baseline TPS reading ever exceeds ~1.20 volts. If it does it even once, this can trigger the code. We'll assume the codes were cleared since the code was initially registered and/or the TPS was replaced.
And since it sounds like you manually set the voltage you desired, I'd set it lower (say 0.70 volts) and see if the code returns. You might have a wandering reading due to wiring issues, a mech hang-up or a bad wiper (though since you replaced the TPS, one would think this is not likely).
Random thoughts. Good luck.
9
94kbvert
  • May 28, 2008
I log the tps voltage and it under a volt at idle, also trying lowering the tps voltage .92 and it still set the code. The code will set while driving around at low speed.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
